23102 Discussions
Loss of third monitor after Graphics or BIOS update
BLothrop
Can I reverse an update run by the Intel Driver & Support Assistant?  After a recent update (I believe it was for the BIOS), I lost the ability to use three monitors.  I have a Dell OptiPlex 7010 (Win 10 64-bit) with two DisplayPort and one VGA connection on which I have been running three VGA monitors for several years.  Since the update, I can only use TWO monitors at a time.  It identifies all three monitors, but will only allow me to enable two – whichever two I choose of the three, but only two at a time.
BLothrop
Intel Graphics Card:  Intel® HD Graphics 2500
    "Device ID" is:  PCI\VEN_8086&DEV_0152&SUBSYS_05771028&REV_09\3&11583659&0&10
System Processor:  Intel® Core™ i5-3570 CPU @ 3.40GHz
n_scott_pearson
Yes, for graphics, you simply run the installer for the previous version of the package. You will then have to watch IDSA and deselect the upgrade driver.
There's a user with Intel HD Graphics 4600 that is seeing the same issue; they cannot get three monitors to work simultaneously. He can select any pair that he wishes but not all three,
AlHill
It is important to note that IDSA has nothing to do with a Dell bios update, if the bios update is part of your problem.
