22925 Discussions
Low fps Counter Strike 1.6 on HD 3000????
Hey, i have a problem with the cs 1.6, my fps are very low, 50 fps is the average, but why?? i hace many games and for example counter strike source, on my intel hd 3000 has average fps 193 fps so how can the 1.6 is soo low???
I see en gpuz when i play cs 1.6 the max gpu core clock was 650mhz, in others games is 1.1ghz so this is the problem??
so intel please fix it?
my spec:
i3 2330m
hd 3000
6gb ddr3 1333mhz ram
whats is the best driver for cs at the moment? I tried lots and I can't find one good
MSchm21
Valued Contributor I
Based on HL2 the 2761 should be fine for CS and since you have a SB CPU the latest 15.22 driver might be worth a try. Maybe you could test all the newest drivers from the four different driver build revisions: 15.21/15.22/15.26/15.28
2761 the same bug... low fps...
will try to test in windows xp
The same occur with Windows XP.... i'm tried with last Windows XP Driver and the same occur... 100 fps, but if you turn flashlight on fps down to 50-60 ... turn off 100 again.... when bombs explodes fps down to 50-60...
believe that is a opengl bug :]
Forgot to say... this bug only occur with OpenGL... in Direct3D Does not have this bug... but some official servers ( like esea or some anticheats ) does not allow to play online in Direct3D
Intel please fix it if possible
I tried in d3d mode, and still the lowest fps, i dont know whats it is, but with gpuz when i play cs never is up to 650mhz
hello i cant play cs 1.6 i need a fix ¬¬
