23526 Discussions
Low fps GTA RP
Abdoul34
Hello, i have an issue while playing gta rp on fivem. I have less than 30 fps. I tried to do some modifications on my gta but it's not solved.
I turn to you to perhaps get an answer to my problem.
Senkuchan
Valued Contributor II
I want to know if this issue occurs only when you use FiveM. I have searched some forums and I have found this link: https://forum.cfx.re/t/low-fps-almost-ever/153680
Also, if you wish to improve your performance, you can check this link: https://thedailyguardian.com/squeezing-out-top-performance-the-right-settings-for-gta-5-and-fivem-to-increase-fps/
To fix this issue, you can update the graphics driver from the Intel website or the HP website. This is the link to the latest Intel generic driver: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html because your logs show that you are using the .5186 version but there is a newer version available.
While this is the link to the driver from your computer manufacturer: https://support.hp.com/us-en/drivers/hp-elitebook-840-g8-notebook-pc/38216725
Abdoul34
Hi, I installed Intel arc control. I didn't get the chance to test the new configuration because of my classes. But I will test it out tonight surely. And will reply properly.
