22943 Discussions
Low score experience index windows 8 vs 7
Hey i installed windows 8 and my score go down,
In windows 7 HP sp1:
Aero Graphics: 6.3
Gamming Graphics: 6.3
Now in windows 8:
Aero Graphics: 5.7
Gamming Graphics: 6.2
why is low?? this are my spec:
i3 2330m
hd 3000
8GB ram (dual channel)
I have the lastest drivers, please a need a fix
AP16
Valued Contributor III
Microsoft scaled up experience index in Windows 8 like it was with Windows 7 vs Vista, so you cannot compare them directly.
i don't believe, because I tried cs source in win 7 and the average fps was 193 fps but in windows 8 with the same setting the average was 150 fps so I think the are driver problem here.
AP16
WEI score is not an absolute metric, like FPS. Its a combination of relative performance numbers, i.e. how your PC is good vs reference one, and ratings given by configuration, i.e. if your PC have between N-1 and N GB RAM, your score is N. In each new version of Windows Microsoft choose newer reference PC to compare with (so your old PC value becomes less) and give slightly different ratings for PC parts (so your 8 GB of RAM get only score 5 instead of 6 in past). Read http://windowsteamblog.com/windows/archive/b/windowsvista/archive/2006/09/22/windows-experience-index-an-in-depth-look.aspx Windows Experience Index: An In-Depth Look for more details about WEI calculation.
No, is not that, because the score of processor, ram, and disk is the same only the graphics is lower, here is a driver problem, performance, because in games in general has low fps compare windows 7, you can open the log file "GraphicsMedia.Assessment (Initial).WinSAT" and compare windows 8 vs 7.
Here windows 7 GraphicsMedia.Assessment (Initial).WinSAT:
TRUE
TRUE
ExpectedFrameCount="300">301
ExpectedFrameCount="150">123
ExpectedFrameCount="150">151<</strong>/DecodeFrameCount>
ExpectedFrameCount="300">151
And here Windows 8 GraphicsMedia.Assessment (Initial).WinSAT:
FALSE
TRUE
ExpectedFrameCount="150">5
ExpectedFrameCount="150">148
Here is the problem the frame count in windows 8 is lower and has problem with HD playback, please intel fix the driver.
I have also noticed the lower WEI score for the desktop graphics on my SAMSUNG NP300, i7 2670QM, 8Gig ram, nVidia Geforce GT 520MX, SAMSUNG 750Gig hdd.
Processor: Win 7 = 7.5 & Win 8 = 7.5
Memory: Win 7 = 7.5 & Win 8 = 7.9 Improvement
Graphics: Win 7 = 6.4 & Win 8 = 5.8 Decrease in performance
Gaming Graphics: Win 7 = 6.4 & Win 8 = 6.4 nVidia & 6.2 HD 3000
HDD: Win 7 = 5.9 & Win 8 = 5.9
I always use the GLclock metal clock by MASA to compare driver performance for the desktop graphics. Intel's latest drivers for Windows 7 gave 560fps, but with Windows 8 only 450fps.
SuperPi 1.5 score 1mill Cal. improveved though, Win 7 12.250sec & Win 8 12.180sec.
Its a driver problem
This is with an I7 2820QM and 1600mhz 9-9-9 Ram On windows 8
C:\>winsat dwmformal
Windows System Assessment Tool
> Video Memory Throughput 6791.87 MB/s
The same laptop used to have a an i3 2350M 1333mhz ram on windows 7
and scored 7500 or 8500 on the Video Memory Throughput i cant remember which
so now that the ram is running at 1600mhz and the gpu now runs upto 1300mhz instead of 1150mhz it should be even higher again
I will be rolling back to windows 7 in the next few days and will do another test with the new cpu and 1600mhz ram
Well the ram has always been 1600mhz but ofc the I3 2350M would only run it at 1333
MEA1
New Contributor II
Same problem here with driver v9.17.10.3062. Hello Intel we need a fix.
Marcos_U_Intel
Hello all,
Microsoft* build the Windows Experience Index tool, so if you are experiencing any issues with the scores, contact Microsoft*directly.
Umm Video Memory Throughput is far lower on the Windows 8 drivers in comparison to the windows 7 drivers
hence the lower scores
I fail to see what contacting microsoft will do
its a driver issue at intel's end and nothing to do with microsoft
MEA1
New Contributor II
@Shonk You're absolutely right. It's Intel's fault not Microsoft.
