COMMENT FAIRE POUR LES REACTIVES .MERCI
Hello Oka1,
- Are you using a pre-built desktop?
- Please provide the brand and model of your system?
- Did you change any settings before the issue started?
- What are the troubleshooting steps that you tried so far?
Michael L.
Hello Oka1,
Michael L.
Nom de l'appareil DESKTOP-70LD4UE
Processeur 11th Gen Intel(R) Core(TM) i7-11700 @ 2.50GHz 2.50 GHz
Mémoire RAM installée 16,0 Go (15,7 Go utilisable)
ID de périphérique C71B070B-EC17-450C-BA84-4708B7215475
ID de produit 00330-54239-34052-AAOEM
Type du système Système d’exploitation 64 bits, processeur x64
Stylet et fonction tactile La fonctionnalité d’entrée tactile ou avec un stylet n’est pas disponible sur cet écran
Édition Windows 10 Professionnel
Version 22H2
Installé le 17/06/2022
Build du système d’exploitation 19045.5371
Expérience Windows Feature Experience Pack 1000.19060.1000.0
Hello Oka1,
Thank you for the update.
Let me gather more information about this for me to figure our what is the exact issue and what is causing it.
- Was it working fine before?
- What is the brand and model of your monitor?
Michael L.
Hello Oka1,
I am just making a follow up on the information that I asked.
Michael L.
Hello Oka1,
I am sending another follow up on the information that I requested.
Michael L.
