23282 Discussions
Make Your Voice Heard: How is gameplay.intel.com working for you?
RonaldM_Intel
Hello Everyone,
Have you visited https://gameplay.intel.com/ https://gameplay.intel.com/ recently? If the answer is no, then we invite you to do it. This is a dedicated site for gamers looking to get the most out of their Intel Graphics.
Back already? Ok, did you find useful information on this site?
If you matched the recommended game settings, were you able to get a better gaming experience? If the answer is no, we are interested in helping you. Please reply to this post with some basic information:
Here's an hypothetical example:
1. Game settings link: https://gameplay.intel.com/GamesSettings/8827/93341/Intel%C2%AE%20Core%E2%84%A2%20i7-6770HQ%20Processor%20(6M%20Cache,%20up%20to%203.50%20GHz) https://gameplay.intel.com/GamesSettings/8827/93341/Intel%C2%AE%20Core%E2%84%A2%20i7-6770HQ%20Processor%20(6M%20Cache,%20up%20to%203.50%20GHz)
2. System configuration
- Motherboard model or laptop model: Intel® NUC6i7KYK
- CPU model: Intel® Core(TM) i7-6770HQ @ 2.8ghz
- Operating System: Windows* 10 Professional 64-bit Anniversary Update
- Graphics driver: 21.20.16.4590
- Memory size: 16GB DDR4
- Monitor model: Acer G257HU 2560x1440@60hz
3. Results: getting low frame rates, < 20
RonaldM_Intel
Taken from RALPHY88 is matching his game settings as indicated in: https://gameplay.intel.com/GamesSettings/8560/0x1916/intel-core-i3-6100u-processor-br-3m-cache-2-30-ghz- Games Settings and gets an average of 20 FPS. System configuration:
- Dell Inspiron 22-3263 All-in-One&# 8232;
- Graphics cannot be upgraded with a new GPU&# 8232;
- FLP, built-in display&# 8232;
- 4 GB RAM (single-channel)&# 8232;
- Hardware Ids- PCI\8086&DEV_1916&SUBSYS_074B1028&REV_07, PCI\VEN_8086&DEV_1916&SUBSYS_074B1028, PCI\VEN_8086&DEV_1916&CC_030000, PCI\VEN_8086&DEV_1916&CC_0300&# 8232;
Software:
- Windows 10 Home (Version 10.0.14393 Build 14393)
- Intel Video BIOS
- Intel HD Graphics 520 Driver (Version 21.20.16.4627)
- Insurgency Video Game (Version 2.4.0.9 CL33269)
Loeschzwerg
Hi Ronald_Intel,
I hope it's OK to share some of my gameplay experience in this thread?
World of Tanks
1. Game settings link: https://gameplay.intel.com/de/GamesSettings/8600/0x193B/Intel®%20Core™%20i7-6770HQ%20Processor%20(6M%20Cache,%20up%20to%203.50%20GHz) World of Tanks // i7-6770HQ
1920x1080, Preset "High", FXAA enabled
- CPU model: Intel® Core(TM) i7-6770HQ @ 2.6ghz (Turbo Boost disabled!); Iris Pro 580 @ 1050MHz
- Operating System: Windows* 10 Professional 64-bit Creators Update (Build 15063.0)
- Graphics driver: 22.20.16.4612
- Memory size: 2x 8GB DDR4-2800
3. Results: Frame rates mostly between 30-40. Absolutely playable from my perspective. Disabling FXAA (like recommended on gameplay.intel.com) gives more performance, but I prefer the improved image quality with FXAA enabled.
https://gameplay.intel.com/GamesSettings/8669/0x1916/intel-core-i3-6100u-processor-br-3m-cache-2-30-ghz- Games Settings
Resolution at 1024x768, Post-process anti-aliasing off
- Laptop Model Lenevo 20G8S0K300
- Processor: Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz (4 CPUs), ~2.3GHz
- Operating System: Windows 10 Home 64-bit (10.0, Build 14393) (14393.rs1_release_inmarket.170303-1614)
- RAM size 8GB
- Intel(R) HD Graphics 520 (iGPU)
- Wide viewing angle & High density FlexView Display 1366x768 (LEN40D5)
Having 20-30 fps after many free tweaks such as updating drivers from intel and editing registry. Fps not high enough for such a competitive shooter game and 1024x768 an eyesore.
Finding gameplay.intel.com not providing enough information to boost one's gaming experience and performance. Hope Intel releases more driver updates that can improve performance since my manufacturer releases updates that doesn't improve performance.
RGrah1
1. Game settings link: https://gameplay.intel.com/GamesSettings/8847/0x1916/Intel%c2%ae%20Core%e2%84%a2%20i3-6100U%20Processor%20(3M%20Cache,%202.30%20GHz) Games Settings
- Motherboard model or laptop model: Dell Inspiron 22-3263 (All-in-One)
- CPU model: Intel® Core(TM) i3-6100U @ 2.3ghz
- Operating System: Windows* 10 Home 64-bit
- Graphics driver: 21.20.16.4627
- Memory size: 4GB DDR3 (single-channel)
- Monitor model: Built-in Display 1920x1080@60hz
3. Results: getting 20 fps and below, unplayable (I have "Application Optimal Mode" turned on in the graphics settings. "Display Power Saving Technology" and "Extended Battery Life for Gaming" are disabled. Windows 10 power plan is on High Performance.)
JWich
Hi Ronald et al,
Apologies if I my question is a bit off topic, but I have run out of ideas where to ask(I actually have nvidia optimus).
My NB:
MSI GE62 7RE Apacahe Pro
Intel i7 kaby Lake
32GB ram dual channel
Windows 10 CU home x64
Nvidia GTX 1050 ti + Intel HD 630 - optimus
Native Full HD monitor @60Hz + LG 4k TV
Intel driver version 21.20.16.4664
For weeks now I am trying to force-disable resolution up-scaling for games in exclusive full-screen mode.
My HDMI output is compliant with version 1.4, so I get only 30Hz when set to 2160p.
I usually game in 720p or 1360*768.
Now if I give the game exclusive full-screen, somewhere on the way to the screen the game's frames get wrapped into a 4k signal, and I end up with max 30fps.
I know for sure that it is possible to have an output signal of 720p@60Hz.
At some point when I was swapping cables, and switching back and forth between native & external screen, suddenly my 4k TV showed 720p at the input. At this point my games became smooth like butter.
Also letting the TV take care of the up-scaling resulted in a very nice and smooth picture. You'd not notice that the signal is only 720p.
I turned off my gear and when I started my PC next time, again I could not get rid of the 4k signal toward the TV anymore.
Unfortunately I was not able to reproduce the 'good' situation anymore since then.
I have tried:
- creating a custom resolution
- making the games appear dpi-aware/unaware via external manifest
- reinstalling windows + all drivers a couple of times
- reverting the TV to factory settings
- various cables
- dxgi hacks
- all kinds of combinations of scaling overrides in the exe's compatibility settings
Since I had this working at some point, there MUST be a way of bypassing any up-scaling on the PC and leave it to the external screen. Maybe some flag in the registry or something similar.
Please look into this, there are millions of gamers with similar setups out there who cannot use the full potential of their HW.
PS.: Please do not suggest things like 'disable v-sync', 'use borderless window', etc. These things help to some extent but are far from the gaming experience I had for only one night when everything ran in 720p@60Hz v-sync on - no stutter, no input lag, simply perfect.
Thanks a bunch for any suggestion in this matter,
jrgn
EDIT
I just realized that I am looking for a simple 'disable GPU scaling button. Since the control panel lacks such a toggle, please advise how to tweak the registry to disable GPU scaling.
Thanks much!
EDIT
RGrah1
Why are all the FPS games on gameplay.intel.com configured to run at 30 fps? I know this because I saw a YouTube video of a laptop with Intel HD Graphics 520 running Call Of Duty: Black Ops 3 at 20-30fps with your configuration. You need 60fps (or at least 45fps in singleplayer) for these games to be playable because you have to be fast-paced in them. 30fps just looks like a slideshow when playing these kind of games. I understand that you focus on bringing the best graphics and detail optimizations possible for Intel HD Graphics, but 30fps is just unacceptable to everyone in some games.
