23769 Discussions
Media Center/4000 Issue
DMado1
I have a different issue with myHD4000 and media center, everything is set to 32bit color but media center reverts to 16 bit color
window 7 64bit
AS-ROCK Vision HT 321B i5-3210M
4 gb memory
any help would be appreciated
DArce
Valued Contributor III
Could you please provide more details on this?
What Media Center software is being used? Is it Windows* media center or something else? When does the issue happen? Does it happen when you just launch the application or when you try to play something?
What driver versions are being used? did it work with a previous driver release? If so, please specify the version that works and the one that does not.
Does the system recover to 32 bit when you close this application?
