23526 Discussions
Vga driver update for latest version makes Battlefield 2 close soon after starting.
EAlve1
My laptop has Intel HD Graphics with first generation Intel 370M processor.
Memory ram: 4 GB dual channel.
Windows 7 64bits.
With Driver 8.15.10.2104 works correctly
Soon after starting the game, and go to select the account he closes without showing any error screen.
The problem was with the Mod "Esmod" but believe affect without mod too.
How do I report a bug in the latest version of the driver?
* when reinstalled the old version in order to play more this does not enable hardware acceleration in Firefox completely.
Fred_D_Intel
Hi livre1,
Would you please POST the Graphics Driver Report? This link will help you to generate the report /thread/41928 http://communities.intel.com/thread/41928
I recommend updating the BIOS of the computer and then testing the game with latest graphics driver. Please let me know if issue persists after that.
EAlve1
The link past is the same topic.
There is no bios update for this notebook.
Recalling that the problem is with the driver, whereas with the old works
I believe that the report request is this:
Intel® HD Graphics (Core i3)
Report Date: 5/31/2013
Report Time[hr:mm:ss]: 19:21:26
Driver Version: 8.15.10.2993
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: Portuguese (Brazil)
DirectX* Version: 10.1
Physical Memory: 3894 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 116 MB
Processor: Intel64 Family 6 Model 37 Stepping 5
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) HD Graphics
Video BIOS: 2009.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Monitor Genérico PnP
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 12,20 inches
Vertical: 06,69 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 E9 02 00 00 00 00
00 14 01 03 80 1F 11 78 0A AA B5 95 58 56 8D 28
1F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 58 1B 56 7E 50 00 0E 30 24 30
35 00 35 AE 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 34 30 57 48 34 2D 54 4C 41 31 00 17
* Other names and brands are the property of their respective owners. *
DArce
Valued Contributor III
Please try the troubleshooting that is posted on this article and post here a checklist of what has been done following the indications on that article.
http://www.intel.com/support/graphics/sb/CS-033945.htm http://www.intel.com/support/graphics/sb/CS-033945.htm
In addition, please confirm if this happens with that specific mod or if it happens to the original game with no mods at all.
EAlve1
All steps done except bios update, because is updated.
The game works without any mod.
The text in the dxdiag log file is very large.
Where do I attach it?
Game closes without any error message *
DArce
You can just copy paste the dxdiag report here, there is no need to attach it as there is no an option to do so.
In the other hand, take under consideration that the issue could be also related to the mod as the game works fine with the latest driver with no mods installed.
