23851 Discussions
Microsoft Windows 8 with Intel Graphics Intel® G41 Express Chipset compatibility
I installed Windows 8 pro 32 bit, in moteboard is integrated video card Intel ® G41 Express Chipset.
My problem is this: having a monitor Samsung 19 "type: 960 BG S, model LS19HJDQHK-EDC, which is not having the manual adjustment of brightness, etc.. Which drivers I can install to fix this problem. With windows you can not to properly adjust.
See Intel System Identification Utility Reference Number: 0136 8055
Il messaggio è stato modificato da: Piero Tamagni&# 13; https://skydrive.live.com/?cid=86b429e1df598508# cid=86B429E1DF598508&id=86B429E1DF598508%21484 https://skydrive.live.com/?cid=86b429e1df598508# cid=86B429E1DF598508&id=86B429E1DF598508%21484
DArce
Valued Contributor III
I suggest that you check the information available on the following article:
/docs/DOC-19646 http://communities.intel.com/docs/DOC-19646
Also check with your display manufacturer and Microsoft* for further troubleshooting on this matter.
