22672 Discussions
Minecraft Forge stopped working outta nothing.
LLuig
Hello!
I have posted this in the Minecraft forums but the only responses i got is:
- Get a new GPU/Graphic Card
- Try fiddling with the settings
I would REALLY appreciate it if you guys would help me!
Uninstalling Java would not let me install Forge.
Original Thread:
Everytime i install the latest Forge or older i get this error when going into the titelscreen.
This nolonger effects Vanilla client.
I also apparently got 2 forge installed with one installer, none of them work.
When starting modpacks from Modpack launchers, it simple has no problems.
Intel drivers updated and this seems a common thing for Intel Drivers.
My one are possible broken but idk how and how to fix it.
Minecraft log:
[10:46:16] [main/INFO]: Setting user: LuigiHarrisMario [10:46:18] [Client thread/INFO]: LWJGL Version: 2.9.1 [10:46:30] [Client thread/INFO]: Reloading ResourceManager: Default, FMLFileResourcePack:Forge Mod Loader, FMLFileResourcePack:Minecraft Forge, FMLFileResourcePack:Not Enough Items, FMLFileResourcePack:Applied Energistics 2, FMLFileResourcePack:Botania, FMLFileResourcePack:BC Builders, FMLFileResourcePack:BC Transport, FMLFileResourcePack:BC Energy, FMLFileResourcePack:BC Silicon, FMLFileResourcePack:BC Robotics, FMLFileResourcePack:BuildCraft, FMLFileResourcePack:BC Factory, FMLFileResourcePack:BuildCraft Compat, FMLFileResourcePack:Carpenter's Blocks, FMLFileResourcePack:CoFH Core, FMLFileResourcePack:ComputerCraft, FMLFileResourcePack:ComputerCraftEdu, FMLFileResourcePack:FastCraft, FMLFileResourcePack:Fossils and Archeology Revival, FMLFileResourcePack:Galacticraft Planets, FMLFileResourcePack:Galacticraft Core, FMLFileResourcePack:iChunUtil, FMLFileResourcePack:IndustrialCraft 2, FMLFileResourcePack:LLibrary, FMLFileResourcePack:Mantle, FMLFileResourcePack:Mekanism, FMLFileResourcePack:MekanismGenerators, FMLFileResourcePack:MekanismTools, FMLFileResourcePack:MineFactory Reloaded, FMLFileResourcePack:MFR Compat: Applied Energistics, FMLFileResourcePack:MFR Compat: BuildCraft, FMLFileResourcePack:MFR Compat: ForgeMicroblock, FMLFileResourcePack:MFR Compat: IC2, FMLFileResourcePack:MFR Compat: Thaumcraft, FMLFileResourcePack:MFR Compat: Tinkers' Construct, FMLFileResourcePack:MFR Compat: Vanilla, FMLFileResourcePack:§9MrCrayfish's Furniture Mod, FMLFileResourcePack:PortalGun, FMLFileResourcePack:Tinkers' Construct, FMLFileResourcePack:TF2 Dispenser, FMLFileResourcePack:TF2 Sentry, FMLFileResourcePack:TF2 TeamAddon, FMLFileResourcePack:TF2 Teleporter, FMLFileResourcePack:Thaumcraft, FMLFileResourcePack:Baubles, FMLFileResourcePack:Forge Microblocks, FMLFileResourcePack:Forge Multipart, FMLFileResourcePack:Minecraft Multipart Plugin, 1.9-Dokucraft-TSC-High.zip [10:46:39] [Sound Library Loader/INFO]: Sound engine started
Crashlog:
[code]
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff903fd2177, pid=8508, tid=5676
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig75icd64.dll+0x12177]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000001f04000): JavaThread "Client thread" [_thread_in_native, id=5676, stack(0x0000000001db0000,0x0000000001eb0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000040007040
Registers:
RAX=0x00007ff903fd2177, RBX=0x0000000040007040, RCX=0x0000000064fd7c94, RDX=0x000000004000704c
RSP=0x0000000001eae570, RBP=0x0000000064ce2fc0, RSI=0x0000000000000c30, RDI=0x0000000064fd7c88
R8 =0x000000000000000c, R9 =0x00007ff903fc0000, R10=0x0000000064ce47b8, R11=0x0000000001eae510
R12=0x0000000000000010, R13=0x0000000000000c30, R14=0x0000000064dcd5d0, R15=0x0000000040007040
RIP=0x00007ff903fd2177, EFLAGS=0x0000000000010206
Top of Stack: (sp=0x0000000001eae570)
0x0000000001eae570: 0000000000000000 0000000000000028
0x0000000001eae580: 000000000000030a 0000000001f04000
0x0000000001eae590: 0000000064fd7c88 00007ff9044c241e
0x0000000001eae5a0: 0000000000009240 0000000064cbb780
0x0000000001eae5b0: 0000000000009240 000000006b2e84b1
0x0000000001eae5c0: 0000000000000000 0000000001eae6e0
0x0000000001eae5d0: 0000000001eae650 0000000001f04760
0x0000000001eae5e0: 000000001675e780 000000006b1ce35b
0x0000000001eae5f0: 0000000019dce408 0000000001f04000
0x0000000001eae600: 0000000001f04000 0000000001eae7e0
0x0000000001eae610: 0000000019dce408 0000000000000000
0x0000000001eae620: 0000000001eae6e0 000000006b2e8697
0x0000000001eae630: 0000000001eae6e0 000000018000b7f0
0x0000000001eae640: 0000000001f04000 0000000001eae6b0
0x0000000001eae650: 0000000064fd7c88 0000000001f04000
0x0000000001eae660: 0000000001f04000 0000000001ef8850
Instructions: (pc=0x00007ff903fd2177)
0x00007ff903fd2157: 48 83 e0 fc 48 03 c8 48 03 d0 49 8b c0 48 c1 e8
0x00007ff903fd2167: 02 48 ff c8 74 16 48 ff c8 74 0b 48 ff c8 75 12
0x00007ff903fd2177: 8b 42 f4 89 41 f4 8b 42 f8 89 41 f8 8b 42 fc 89
XXXWHITESPACEX...
In order to be able to fix this error with Minecraft Forge you can try the following:
First remove the driver from device manager, just right click on it, and choose the option delete and try the game that way, without the driver.
Also, you can always try the following driver, it is the latest version for Intel® HD Graphics 4600, which is the version that the Intel® i5-4590 has.
Here is the link for the driver:
https://downloadcenter.intel.com/download/25951/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496 https://downloadcenter.intel.com/download/25951/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496
Another option will be to delete the driver again from device manager and install it manually, here is the link to install it manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
This problem, happened since day one, or it was working fine before?
What is the error message that you are getting?
Alberto
LLuig
Hello.
The error message is crashlog. Minecraft only shows a part of it.
This has been haappening for a time now, this just started outta random.
I have tried the driver but it's saying my computer does not have the needs to have it and thus i did not manually install this.
If i delete the driver will i able to throwback it or do i need to download a new one?
Hello:
Thank you for providing that information about the error message, it is very useful for us.
The driver that I gave you is the one that it should work for that processor, since the processor you have is the Intel® i5-4590 and the graphics version for it is Intel® HD Graphics 4600.
Yes, if you delete the driver you will be able to install any of the versions for that driver, the first one or the latest one.
Please let me know if the Minecraft Forge game works fine after you installed the driver manually.
Alberto
LLuig
I have tried installing it manually but it simply cannot find it.
I am gonna try deleting the driver and redownloading it!
Hello:
Perfect, please try that and let me know results, so we can further assist you.
Alberto
LLuig
Hi Alberto,
I have deleted the Driver and restarted my pc!
it reinstalled it and messed up my desktop which is fine, it fixed the issue and made it work again.
Thank you for your support!
LuigiHarrisMario out
LLuig
I was wrong.
It only worked once.
Hello:
In order to further assist you we need to know some details about the system that you are using, please run the following tool so we can get that, here is the link to install it:
SSU tool (System Support Utility)
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Once you do that, the tool will allow you to save the information as a file, so, once you save it, please attach it to this thread.
Alberto
LLuig
Here you go!
LLuig
Any update?
It's been 3 days...
Hello:
Since you already try to install the driver manually and the problem remains, let me give you the steps for a different method of installation:
1. Login with administrator privileges
2. Open Control Panel
3. Open Device Manager
4. Click on "Display adapters"
5. Double click "Intel HD Graphics"
6. Click on the "Driver" tab
7. Click on "Update Driver" button
8. Click on "Browse my computer for driver software"
9. Click on "Let me pick from a list of device drivers on my computer"
10. Click on "Have Disk" button
11. Click "Browse"
12. Navigate to the folder that you unzipped the Intel HD Graphics driver to
13. Navigate to the Graphics sub-folder
14. Double click the igdlh64.inf or igdlh.inf file <-- depends on if you have 32 or 64 bit OS<p> 15. Click "OK"
16. Click "Next", Driver should now be installing.
17. If successful, click "Close", Reboot.
Also, on the following link you will find the recommended settings to play Minecraft, so, please verify those in order to make it work properly, please select the option that says "download screenshots":
https://gameplay.intel.com/GamesSettings/7353/80815/Intel%C2%AE%20Core%E2%84%A2%20i5-4590%20Processor%20(6M%20Cache,%20up%20to%203.70%20GHz) https://gameplay.intel.com/GamesSettings/7353/80815/Intel%C2%AE%20Core%E2%84%A2%20i5-4590%20Processor%20(6M%20Cache,%20up%20to%203.70%20GHz)
Alberto
LLuig
Big cookie for you! Thank you for your help!
Hello:
You are welcome, I really appreciate your feedback, thank you very much.
Alberto
