23586 Discussions
Minecraft Java has blurry graphics in windowed mode and part of the screen is cut off
JLa1
Minecraft Java in windowed mode has blurry graphics, but in fullscreen mode it's sharp like normal. Also part of the screen is cut off on all sides.
See how the top right text is cut off.
You can't exactly see the blur in the photos but you can definitely see the text cut off. I have an Intel HD 620 and an i5-7200u.
Hello Jacky161,
I understand you are getting blurry graphics in Minecraft*.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Has it worked fine before?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
JLa1
Minecraft has worked fine before probably on older driver versions. Here's my TXT file.
Hello Jacky161,
Thanks for the information you sent to me.
I would like you to try reinstalling previous version of the graphics driver. Please download it from this link https://downloadmirror.intel.com/26669/eng/win64_154516.4627.zip https://downloadmirror.intel.com/26669/eng/win64_154516.4627.zip
As soon as the graphics driver has been downloaded on the keyboard press WinLogo key + r, then type in devmgmt.msc, double click on Display Adapters -> Intel HD Graphics -> Driver tab -> Uninstall -> Select the check box Delete the driver software for this device -> OK, restart the computer, and then reinstall the graphics driver with the steps that are on this YouTube video https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
If issue persists try updating Java application from this other link https://www.java.com/en/download/ https://www.java.com/en/download/
Let me know if issue persists or not.
Fred D.
JLa1
It seems like the older driver fixed it. Thanks! But now I won't have all the improvements in the newer driver version.
Hello Jacky161,
I am glad to hear the issue has been fixed with previous graphics driver.
I will forward this feedback to our development team so they can take a look at it.
Fred D.
Hello Jacky161,
Newer version of the graphics driver was recently released, would you please install it and let me know if issue persists?
You can download latest graphics driver from this link https://downloadmirror.intel.com/26941/eng/win64.zip https://downloadmirror.intel.com/26941/eng/win64.zip
As soon as the graphics driver has been downloaded install it with the steps that are on this YouTube video https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Fred D.
JLa1
Sorry I didn't see this post. I completely forgot about this. It seems that the latest driver I just installed fixed the problem.
Hello Jacky161,
That is great to hear and thank you for taking the time and provide the feedback. I appreciate it.
Allan J.
