22970 Discussions
Minecraft is crashing on windows 10
RAndr6
I think it's very funny.. I have a dual boot. On Linux it Works well.
But on Windows 10. It crashes.
Can you help with it ?
Here is the log
---- Minecraft Crash Report ----
// I'm sorry, Dave.
Time: 4/8/17 7:48 AM
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bes.ap(SourceFile:600)
at bes.an(SourceFile:436)
at bes.a(SourceFile:383)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.11.2
Operating System: Windows 10 (x86) version 10.0
Java Version: 1.8.0_121, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 16666040 bytes (15 MB) / 61075456 bytes (58 MB) up to 518979584 bytes (494 MB)
JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.11.2
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: Yes
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU:
AlHill
What is the complete processor model number?
Doc
RAndr6
My processor is Mobile Intel(R) 4 Series Express Chipset Family.
I've tried to update the driver to use from Intel, but Windows 10 doesn't update it.
Gives an error.
Do you want the log ?
[0924:1564][2017-04-08T08:11:48]i001: Burn v3.7.1224.0, Windows v6.2 (Build 9200: Service Pack 0), path: C:\Users\ninap\Downloads\Intel Components\SetupChipset.exe, cmdline: ''
[0924:1564][2017-04-08T08:11:48]i000: Initializing string variable 'IIF_ProductVersion' to value '10.1.1.14'
[0924:1564][2017-04-08T08:11:48]i000: Initializing string variable 'IIF_InstallerVersion' to value '3.1.6'
[0924:1564][2017-04-08T08:11:48]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx86.msi' to value ';NullDrivers.cab;NOT VersionNT64'
[0924:1564][2017-04-08T08:11:48]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx64.msi' to value ';NullDrivers.cab;VersionNT64'
[0924:1564][2017-04-08T08:11:48]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\ninap\AppData\Local\Temp\Intel\Logs\Chipset_20170408081148.log'
[0924:1564][2017-04-08T08:11:48]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\ninap\Downloads\Intel Components\SetupChipset.exe'
[0924:1564][2017-04-08T08:11:48]i052: Condition 'VersionNT >= v6.1 OR (VersionNT = v6.0 AND NTProductType = 3)' evaluates to true.
[0924:1564][2017-04-08T08:11:48]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Chipset Device Software'
[0924:1564][2017-04-08T08:11:48]i000: Loading managed bootstrapper application.
[0924:1564][2017-04-08T08:11:48]i000: Creating BA thread to run asynchronously.
[0924:1ED8][2017-04-08T08:11:48]i000: ** MBA ** Command line:
[0924:1ED8][2017-04-08T08:11:49]i000: Setting string variable 'WixBundleName' to value 'Software de dispositivo do Chipset Intel®'
[0924:1ED8][2017-04-08T08:11:49]i000: ** MBA ** Calling Engine.Detect()
[0924:1564][2017-04-08T08:11:49]i100: Detect begin, 3 packages
[0924:1564][2017-04-08T08:11:49]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\NET Framework Setup\NDP\v3.5'
[0924:1564][2017-04-08T08:11:49]i000: Setting string variable 'DotNet40Client' to value '1'
[0924:1564][2017-04-08T08:11:49]i000: Setting string variable 'DotNet40Full' to value '1'
[0924:1564][2017-04-08T08:11:49]i000: Setting string variable 'DotNet45' to value '460798'
[0924:1564][2017-04-08T08:11:49]i052: Condition 'DotNet35 OR DotNet40Client OR DotNet40Full OR (DotNet45 >= 378389)' evaluates to true.
[0924:1564][2017-04-08T08:11:49]i101: Detected package: DotNet45, state: Present, cached: None
[0924:1564][2017-04-08T08:11:49]i101: Detected package: SetupChipsetx86.msi, state: Absent, cached: None
[0924:1564][2017-04-08T08:11:49]i104: Detected package: SetupChipsetx86.msi, feature: NullDriverFeature, state: Absent
[0924:1564][2017-04-08T08:11:49]i104: Detected package: SetupChipsetx86.msi, feature: PackageVersionFeature, state: Absent
[0924:1564][2017-04-08T08:11:49]i104: Detected package: SetupChipsetx86.msi, feature: LicenseAgreementFeature, state: Absent
[0924:1564][2017-04-08T08:11:49]i101: Detected package: SetupChipsetx64.msi, state: Absent, cached: None
[0924:1564][2017-04-08T08:11:49]i104: Detected package: SetupChipsetx64.msi, feature: NullDriverFeature, state: Absent
[0924:1564][2017-04-08T08:11:49]i104: Detected package: SetupChipsetx64.msi, feature: PackageVersionFeature, state: Absent
[0924:1564][2017-04-08T08:11:49]i104: Detected package: SetupChipsetx64.msi, feature: LicenseAgreementFeature, state: Absent
[0924:1564][2017-04-08T08:11:49]i199: Detect complete, result: 0x0
[0924:1564][2017-04-08T08:11:58]i200: Plan begin, 3 packages, action: Install
[0924:1564][2017-04-08T08:11:58]w321: Skipping dependency registration on package with no dependency providers: DotNet45
[0924:1564][2017-04-08T08:11:58]i052: Condition 'NOT VersionNT64' evaluates to true.
[0924:1564][2017-04-08T08:11:58]i204: Plan 3 msi features for package: SetupChipsetx86.msi
[0924:1564][2017-04-08T08:11:58]i203: Planned feature: NullDriverFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[0924:1564][2017-04-08T08:11:58]i203: Planned feature: PackageVersionFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[0924:1564][2017-04-08T08:11:58]i203: Planned feature: LicenseAgreementFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[0924:1564][2017-04-08T08:11:58]i000: Setting string variable 'WixBundleRollbackLog_SetupChipsetx86.msi' to value 'C:\Users\ninap\AppData\Local\Temp\Intel\Logs\Chipset_20170408081148_0_SetupChipsetx86.msi_rollback.log'
[0924:1564][2017-04-08T08:11:58]i000: Setting string variable 'WixBundleLog_SetupChipsetx86.msi' to value 'C:\Users\ninap\AppData\Local\Temp\Intel\Logs\Chipset_20170408081148_0_SetupChipsetx86.msi.log'
[0924:1564][2017-04-08T08:11:58]i052: Condition 'VersionNT64' evaluates to false.
[0924:1564][2017-04-08T08:11:58]i204: Plan 3 msi features for package: SetupChipsetx64.msi
[0924:1564][2017-04-08T08:11:58]i201: Planned package: DotNet45, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0924:1564][2017-04-08T08:11:58]i201: Planned package: SetupChipsetx86.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[0924:1564][2017-04-08T08:11:58]i201: Planned package: SetupChipsetx64.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0924:1564][2017-04-08T08:11:58]i299: Plan complete, result: 0x0
[0924:1ED8][2017-04-08T08:11:58]i000: Setting string variable 'IIF_MSI_SWITCHES' to value ''
[0924:1ED8][2017-04-08T08:11:58]i000: ** MBA ** Getting window handle.
[0924:1ED8][2017-04-08T08:11:58]i000: ** MBA ** Calling Engine.Apply(). Window handle: 67000
[0924:1564][2017-04-08T08:11:58]i300: Apply begin
[1BB0:1F88][2017-04-08T08:12:02]i000: Caching bundle from: 'C:\Users\ninap\AppData\Local\Temp\{619e726e-d2b4-4e28-9568-c964fd81ee6c}\.be\SetupChipset.exe' to: 'C:\ProgramData\Package Cache\{619e726e-d2b4-4e28-9568-c964fd81ee6c}\SetupChipset.exe'
[1BB0:1F88][2017-04-08T08:12:02]i320: Registering bundle dependency provider: {619e726e-d2b4-4e28-9568-c964fd81ee6c}, version: 10.1.1.14
[1BB0:0F2C][2017-04-08T08:12:02]i305: Verified acquired payload: SetupChipsetx86.msi at path: C:\ProgramData\Package Cache\.unverified\SetupChipsetx86.msi, moving to: C:\ProgramData\Package Cache\{23312E5E-F714-4F0B-97F5-4A7E2DEFE61E}v10.1.1.14\SetupChipsetx86.msi.
[1BB0:0F2C][2017-04-08T08:12:02]i305: Verifi...
AlHill
That is not the processor model number. However, it is enough. Your Mobile 4 series express chipset is not supported on Windows 10.
Look WAY DOWN this page under Legacy Intel Graphics products: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
Doc
Thank you very much to Al Hill for the information provided above.
djrondon,Thank you very much for joining the Intel® graphics communities.
As you can confirm on the link provided above, there are no drivers available for Windows® 10, just in case, on the link below you will see the drivers we have available for Mobile Intel® 4 Series Express Chipset Family:
https://downloadcenter.intel.com/product/81507/Graphics-Drivers-for-Mobile-Intel-4-Series-Express-Chipset-Family https://downloadcenter.intel.com/product/81507/Graphics-Drivers-for-Mobile-Intel-4-Series-Express-Chipset-Family
Any further questions, please let me know.
Alberto
