22680 Discussions
Mobile Intel 4 GMA driver will not install or uninstall on Lenovo X301 laptop
Machine: Lenovo X301 Laptop with SSD drive, 4GB of memory
OS: Windows 7 Professional 32 bit
Video Driver: Mobile Intel 4 Series Express Chipset Family
Problem:
After installing Visual Studio 10 and doing Windows Update, Intel video drivers were destroyed. Two instances of the Mobile Intel 4.... driver show up in Device Manager. Both have have a yellow indicator of unhappiness.
Only Error Message: "An error occurred while registering one or more components"
Symptoms:
"Connect to a Projector" applet will not load. Nothing happens when icon is clicked.
System was in 800x600 resolution after Windows Update. 1400x900 is default.
Cannot extend to another monitor that is plugged in.
Cannot update, install or delete Mobile Intel 4 Series.. driver instances under Display Adapter in Device Manager. Trying either fails without any error message.
Cannot install the update for this driver. It, 7xd557ww.exe, fails after copying files when the "Install GMA5 Display Driver now " install begins. The install app just goes away without any message. This happens in Diagnostic or Safe mode.
Would updating the BIOS help? I have no idea on why everything fails.
I have a lot of software on this machine, and am mightily concerned about having to install the OS again. Any help would be appreciated.
DArce
Valued Contributor III
You could try using a system registry fix or cleaner software or trying with a operating system repair or trying a restore point to a previous state.
You can also try to check with Microsoft* to see if there is a way to force the installation of the driver.
If the issue persists a reinstall may be required as the last option.
My company pushed out a set of Microsoft updates last night, and the laptop refused to reboot. OS is now being re-imaged .
