23707 Discussions
Mobile Intel (R) 4 drivers
Hello.
I have a DELL Latitude E6400 that comes with a Mobile Intel (R) series 4 video card, I'm currently running on windows 7 x64 bit, my problem is that some of the games ( that I used to play under XP ) cannot be played anymore, Example: MoH:AAS, previously on my old desktop, I had a Nvidia card, when I installed Win 7 I had the same problem, and the solution was to download the video drivers for windows xp, I'm trying to do the same with Intel ones, but it doesn't seem to work, it doesn't let me install such drivers 😕
Is there a solution for this? thank you.
If these games are not included within the following list, that means Intel has not tested them for this specific graphics controller yet.
http://support.intel.com/support/graphics/sb/cs-012643.htm http://support.intel.com/support/graphics/sb/cs-012643.htm
Therefore you may try ajusting the settings within the game or you may try reinstalling the graphics driver with "compatibility mode" for Windows* XP, in order to do this you should:
1. Right click on the installation driver file,
2. Select Properties.
3. Select Compatibility tab.
4. Select Windows* XP
5. Install the driver again.
Dago MC
That helped, thank you!
