23791 Discussions
Monitor Hertz Problem Related To Drivers
Hinterlegung
I have a "Lenovo LOQ 15IAX9I - Type 83FQ" model gaming laptop. I was using this laptop with my Asus TUF Gaming Vg249Q model monitor with 144hz refresh rate perfectly. But after recent graphic card updates i am getting max 120 hz. It started to  happen after "Intel® Arc™ & Iris® Xe Graphics - Windows* 32.0.101.5768" drivers are gone. Back then, if i reinstall that version of Intel graphic drivers my solution was gone. But now, i cant find that graphic drivers to install. Here is my question;
1- Can somebody direct me to "32.0.101.5768" download link in any possible way 🙂
2- How can we solve this problem on new version of Intel graphic drivers. Because i see in forums there are dozens of people which suffer from this problem too.
MUC
Honored Contributor I
Lenovo LOQ 15IAX9I - Product Specifications Reference
The ASUS TUF Gaming VG249Q monitor also features a DisplayPort. Please also consider connecting the monitor to the USB Type-C port on the right side of the laptop to enable VESA Adaptive Sync (variable refresh rate). Compatibility with monitors is generally better via the DisplayPort protocol than via HDMI.
Use one of these cables:
