23741 Discussions
Monitor parpadea
Cinderblox94
Desde hace unos meses enchufo un monitor por hdmi, que cuando quiere parpadea, aleatoriamente, a veces durante un segundo y otras durante 10, por lo general pasa más cuando tengo abierto algo en esa pantalla
AlHill
I  would try a better quality HDMI cable.
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
Cinderblox94
Este es el 3er cable hdmi que uso distinto, concretamente ahora uso el mismo que viene con la switch, que parece de mejor calidad. I atach the specs of the INtel Support Utility
AlHill
You have dual graphics.  You should use BOTH the intel and nvidia drivers PROVIDED by Asustek.
Test with those drivers.
Doc
Cinderblox94
But the monitor is only controlled by the intel, i haven't found a way of controlling with nvidia's
AlHill
Again, use BOTH the nvidia and intel drivers provided by Asustek.
Doc
