23851 Discussions
Intel UHD Graphics 620 optimization options for gaming
EtsWindows1018
Hi, I'm new here. I have a question regarding the built-in display adapter/GPU on my Acer Swift 3 SF314-56.
The question is: how do I optimize the Intel UHD Graphics 620 for gaming and video editing???
also, in case you need the specs for my Swift 3, here:
CPU: Intel Core i5 8265U
Memory: 8GB RAM (4gb built-in, 4gb removable)
Storage: 128gb SSD with 1tb HDD
Graphics: Intel UHD Graphics 620
Sebastian_M_Intel
Hello EtsWindows1018,
Thank you for posting on the Intel® communities.
Please check the following information:
  • For different games, you can use gameplay.intel.com for the supported games with recommended settings depending on your Intel® processor.
  • For video editing software it might depend on the software's requirement, you might want to check with the developer's for recommended settings and system requirements.
  • For overall performance, it is recommended to always have drivers, BIOS, Operating System, Apps, and Games up to date.
  • Also, most new Intel® graphics will use up to 50% of physical memory for video memory, which also improves performance, therefore; increasing memory is also useful. Check here for more information.
  • Keep in mind that some manufacturers (OEM) enable or disable some features via the design of the laptop, so you can also check with Acer* for best performance settings.
Sebastian M.
Intel Customer Support Technician.
Sebastian_M_Intel
Sebastian M.
Sebastian_M_Intel
I noticed that my previous reply was marked as a solution, therefore; this thread is marked as solved.
Based on that, we will close this inquiry, however; if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sebastian M.
