23090 Discussions
Motherboard and graphics card compatibility
LMile6
I want to upgrade my gpu to a gtx 1650 super and my motherboard is a DQ77MK and I want to know if it is compatible. Thanks.
AlHill
Very difficult to say. The answer is maybe, maybe not. The best I can tell you is to make sure your DQ77MK bios is updated first. Then, carefully select the graphics card, and make sure it has a good return policy.
Doc
n_scott_pearson
I would also make sure you enable and boot using UEFI Boot. This can make a difference in compatibility.
