23851 Discussions
Mouse click offset in some applications
JDehe
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
In some applications there is a vertical offset between the cursor position and the mouse click and motion events (attached GIF example). The problem only appears when the application is started with the Intel(R) HD Graphics card, and disappears when the application is forced to use the NVIDIA graphics card. This GitHub issue https://github.com/godotengine/godot/issues/8902 https://github.com/godotengine/godot/issues/8902 suggests that the problem does not appear with older driver versions.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Intel(R) HD Graphics 530
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Yes, NVIDIA GeForce GTX 960M
<td style="border-top: none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; border-left: none; padding: 0 5.4pt; font-style: inherit;" width="299"...
Hello j.dehesa,
Thank you for joining our Intel ® Community.
We are currently working on the issue replication of your issue.
We noticed that you are running an older version (21.20.16.4664) of the OEM driver for your system, have you tried to run the latest driver (23.20.16.4973) from Dell*?
https://www.dell.com/support/home/us/en/04/drivers/driversdetails?driverId=10X01 Here is the link for you to test it.
I hope this helps.
Diego S.
Hello j.dehesa,
I hope this helps.
Diego S.
JDehe
Hello Diego,
Thank you for your answer, the updated driver does indeed fix the issue. I should just add that I did check for updates with Intel and Dell updating tools, and in both cases it was indicated that my drivers were up to date (I do not know who is responsible for this really). In any case, it is fixed now, so it is fine.
Best,
Javier
