23777 Discussions
Well known Valve Source 1 engine bug
FMerw
Hello
I am just reporting a bug affecting many many games using the Valve Source 1 engine and Intel GPU's.
My Intel GPU is UHD630.
Here is the Github link
https://github.com/ValveSoftware/Source-1-Games/issues/2523
This affects Intel UHD630, HD Graphics 520 and 530 (and maybe more Intel GPUs).
I've noticed that in CS:GO in maps which make use of the Ambient Occlusion / Tonemapping feature, like de_lake or de_canals the maps are way too dark when playing. The maps display correctly when dead/spectating or watching gotv. As soon as you die, the whole map brightens up like it always should be, after spawning it darkens down to an almost unplayable level.
After researching this a bit it seems CS:GO, L4D2 and probably other Source games are affected by this issue, and maybe even more Intel Graphics Chipsets.
The workaround is to add the following to video.txt:
"setting.mat_tonemapping_occlusion_use_stencil" "1"
I have a Intel HD 520 (i5-6300U) using Intel Graphics Drivers Version: 15.60.2.4901 (Latest)
OS: Windows 10 Pro (Fall Creators Update)
Here are some links for reference:
https://github.com/ValveSoftware/csgo-osx-linux/issues/443 ValveSoftware/csgo-osx-linux# 443 (it's also affecting Windows not only Linux)
https://www.reddit.com/r/l4d2/comments/4rm90g/darkness_bug/ https://www.reddit.com/r/l4d2/comments/4rm90g/darkness_bug/
http://steamcommunity.com/app/550/discussions/0/357287935541576094/ http://steamcommunity.com/app/550/discussions/0/357287935541576094/
https://steamcommunity.com/app/730/discussions/0/1471967615861847420/ https://steamcommunity.com/app/730/discussions/0/1471967615861847420/
https://steamcommunity.com/app/730/discussions/0/412446890551220183 https://steamcommunity.com/app/730/discussions/0/412446890551220183
Hello, John238. Thank you very much for sharing your issue with the Intel Communities Team. I will be more than glad to assist you.
We will definitely pass this information to the proper team. Then, please try installing the latest graphics drivers for your system (6229) and let us know how it goes:
  1. Here is the download link for the latest graphics drivers: https://downloadmirror.intel.com/27894/a08/win64_24.20.100.6229.zip https://downloadmirror.intel.com/27894/a08/win64_24.20.100.6229.zip
  2. In order to install them, please follow this guide: https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html
Antony S.
Hello, John238.
I would like to double check if you were able to perform the troubleshooting steps that I attached to the post above and the results.
Antony S.
FMerw
Hello Anthony
I did install the latest Intel gpu drivers. The problem persisted. I am not sure what cause the problem, its either a bug in the Source 1 engine or the Intel GPU drivers.
I have since got back my Nvidia card wont be able to test the onboard Intel GPU drivers any further, though I am sure many gamers use their onboard Intel GPU for CSGO and it would be awesome if this bug could be fixed. The visuals when playing CSGO is really much darker and not a good experience.
Thank you very much for your response, John238.
For us to continue researching into this issue, can you please share with us the .txt file that the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility will generate while using the Intel® HD Graphics controller. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Antony S.
Hello, John238.
I would like to know if you could generate the report requested above?
Antony S.
Hello, John238.
Allow me to share with you that there is currently an internal bug report [ID# : 1806170079] which is under investigation.
Once we have an update we will post it in the following thread: /message/545410 https://communities.intel.com/message/545410
Antony S.
FMerw
Hello Antony.
This is not the same bug as I am having.
Thank you for your response, John238.
We really appreciate your feedback. We are currently working into this issue.
Antony S.
