23661 Discussions
Movie Maker 12
CTăbî
Hello, my name is Cătălin..
I've just installed Windows Essentials 2012 ( full, with all its programs ) and movie maker refuses to start.
It's that problem with the graphic card / system requirements not met.
But i have had windows essentials 2012 installed before, but i have just re-installed my windows 1 month ago.
It's a Samsung laptop. Samsung 300E5Z-A03 to be more specific.
Here are some info about it, which i have read on google it's important or w.e.
I just don't get it, why it worked for about 7-8 months until i re-installed my windows, and now it's not working.
I specify that i have installed the same windows.
CTăbî
Nevermind, /message/197675# 197675 https://communities.intel.com/message/197675# 197675 this thread solved my problem after i installed that driver.
thanks anyway!
CTăbî
thanks anyway!
Silvia_L_Intel1
I'm glad to know you were able to find a solution for your issue.
CTăbî
And it doesn't work again..
Any driver/update that can work with movie maker and still gives maximum performance for gaming ( SA-MP ) ??! It's annoying.. the driver which it worked on, doesn't give the same performance at gaming .. anything?
Silvia_L_Intel1
Please try installing the latest graphics driver available. It was released a few days ago https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24329&lang=eng&ProdId=3524 Intel® Download Center
CTăbî
The system doesn't meet the requirements to install, i get this error.
JEFFREY_F_Intel
Sylvia steered you wrong here - the driver posted a few days ago doesn't apply to your system.
Your CPU is Pentium B950 (Sandybridge generation, I believe); latest driver was for Ivybridge/Baytrail generation. The latest driver for your system is 15.28.3517, I believe:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3319 Intel® Download Center
Not sure what you mean by "maximum performance for gaming" versus movie maker working.
Silvia_L_Intel1
You are right rootheday, the correct driver version is v3517 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23764&lang=eng&ProdId=3319 Intel® Download Center
Tcc199, When user are installing ours drivers and you are getting this kind of error, most of the time is because the OEM system does not allow the installation of them and it will be necessary to install the graphics drivers provided by the system manufacture.
You may try forcing the installation by performing manual procedure; however I cannot assure you they are going to work as expected.
See here for instructions: http://support.intel.com/support/graphics/sb/CS-022355.htm Graphics Drivers — Computer manufacturer graphics driver detected
CTăbî
