23774 Discussions
Mudbox Requires a Newer Intel Graphics Driver
thaf
I isntalled Mudbox on HP Elitebook 820 g1 (GPU Intel HD Graphics family) and updated to the latest driver. However, when run Mudbox I recieve message Mudbox Requires a Newer Intel Graphics Driver. I tried Mudbox 2015 and 2016 and get the same result.
any clue?
IUman
Could you please provide me with your system processor model and the operating system you are using?
thaf
CPU: Interl(R) Core(TM) i5-4310U CPU @ 2.00GHz 2.6 GHz
OS: Windows 7 Enterprise 64-bit SP1
GPU: Intel HD Graphics 4400
IUman
I appreciate you have replied with that information; I was doing a further research to find out the reason why you are not able to run your Mudbox software, at this point it looks like it is not compatible with the system you have, you will need a more powerful system to run this software.
You can find the recommended hardware for this software at:
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=system&product_group=7&release=2015&os=8192&manuf=2&opt=0nNOTE http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=system&product_group=7&release=2015&os=8192&manuf=2&opt=0nNOTE:
Also, you can try contacting the Mudbox developers to find out if they have a workaround to run this software in this computer.
thaf
Thank you! Will check with Autodesk.
