23806 Discussions
Multiple monitors fail initialization using MST switch with Windows 10
GDyck
If I have multiple monitors connected to a MST switch, when Windows is started or awakened from a sleep state the monitors fail to initialize. If the internal monitor is enabled I find system performance is sluggish, as if a process is hung in a loop consuming CPU. When a single monitor is connected to the MST switch it is initialized properly, and I can connect additional monitors and they are initialized properly.
Topology screen shots and a dxdiag report are attached in the attached document.
AndrewG_Intel
Hello GDyck,
In order to understand better this environment, could you please provide or confirm the following information?
1- Did this configuration worked before? If so, was any update, software or hardware change?
2- Please confirm how many monitors/displays in total you are trying to use with this configuration (including external monitors and built-in display):
3- Brand, models and part number of every monitor:
4- Could you please elaborate more on the configuration and how the devices are connected to one another? For instance: Laptop >> Docking >> MST splitter >> Monitors using DVI cables from MST splitter to monitors?
5- Are the cables and/or DVI video ports "DVI Single-link" or "DVI Dual-link"?
6- Please provide a Report for Intel® Graphics Drivers using the configuration you are trying to achieve. To generate the report, please follow the steps in the below link:
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics-drivers.html
Andrew G.
A Contingent Worker at Intel
AndrewG_Intel
Hello GDyck,
If you need further assistance, please let us know. We will be glad to assist you.
Andrew G.
AndrewG_Intel
Hello GDyck,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Andrew G.
