23102 Discussions
My Intel HD 4000 driver crashes when I try to run Fallout4
JGood4
I am currently running the following system:
Toshiba Satellite S855 with an i7-3630QM CPU
Intel Graphics HD 4000 with driver version 10.18.10.3345.
When I run Fallout 4, I get a system error that says windows successfully recovered from an unresponsive driver. I have attempted to download the most current driver and roll back to the earliest driver to correct this problem. When I completely uninstalled the driver and used the windows default graphics driver, I was able to get the system to run. The problem is that when I do that, I get no use of the hardware acceleration and the system gets 3 to 5 frames per second. Is there an intel driver that might correct this problem that I have not tried?
Thank you
Jason
Allan_J_Intel1
Please test downloading and installing driver version 4276 here https://downloadcenter.intel.com/download/25313/Intel-HD-Graphics-Driver-for-Windows-7-8-1-10-3rd-Gen-BYT- Download Intel® HD Graphics Driver for Windows® 7*, 8.1*, 10 (3rd Gen & BYT)
Allan.
JGood4
Good Moring Allan,
I tried to install this driver, but it said that my system does not meet minimum requirements. Is there an older version of this driver that I can install?
Jason
Allan_J_Intel1
See the list of downloads for your graphics controller here:
https://downloadcenter.intel.com/product/81499/Intel-HD-Graphics-4000-for-3rd-Generation-Intel-Core-Processors Downloads for Intel® HD Graphics 4000 for 3rd Generation Intel® Core™ Processors
Allan.
