22931 Discussions
My Intel HD Graphics 4000 does not update the drivers for the Intel software !
JMend13
My Intel HD Graphics 4000 does not update the drivers for the Intel software, need to update it, right after downloading and INSTALLING program asks to restart the computer, and when I restart back remains the same version of the drivers.
Note: Notebook HP Pavilion G4
Please, help me !!
IUman
Hello LEON007,
Thank you for joining the Intel communities.
When you try to install the driver the installation goes all the way through or stops at some point?
Please reply with your graphics report:
Go to Intel® Graphics and Control Panel > Options > information Center > Save.
Or you can check the following link to get the report:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html Intel® Graphics Driver Report for Graphics Drivers
Also, I will appreciate if you can post the msinfo32.
  1. Please press Windows Key + R to open the Run Menu
  2. Type msinfo32 and click OK
  3. While viewing the System Summary node go to File then Save (Please do not use Export)
  4. Save your MSINFO32 report as msinfo32.nfo on your desktop for easy access and then you can post it here.
Ivan
KLauw
Eh . I got problem like him . I had copy frm my Laptop (I cant post the msinfo32. cause the attach files don't support .nfo so I just put the Pictures n thres my Graphic Properties)
WHAT SHOULD I DO
Intel(R) HD Graphics 4000
Report Date: Thursday, February 4, 2016
Report Time [hh:mm:ss]: 1:42:53 PM
Driver Version: 10.18.10.4358
Operating System: Windows* 10 Pro (10.0.10586)
Default Language: English (Indonesia)
Installed DirectX* Version: 12.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 3943 MB
Processor: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
Processor Speed: 2594 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 2132.0
Current Resolution: 1366 x 768
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
Serial Number: LGD033c
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: LVDS
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 12.2 inches
Vertical Size: 6.69 inches
Supported Modes
1366 x 768 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 3C 03 00 00 00 00
00 15 01 03 80 1F 11 78 0A A9 25 96 58 57 8E 28
1F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 58 1B 56 7E 50 00 0E 30 24 30
35 00 35 AE 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 34 30 57 48 34 2D 54 4C 4E 31 00 43
* Other names and brands are the property of their respective owners.
ivanu_intel
JMend13
Hello IVANU INTEL, thanks for helping me, the data you requested is below ...
https://drive.google.com/folderview?id=0B1FXodVodir_UG1IejNYTUZEYkE&usp=sharing Intel
I put the file on google drive to download, because the msinfo can not be attached.
IUman
Thank you for the information you have kindly provided.
Please try uninstalling the older driver or the driver you have installed and restart your system.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver and Intel Display HDMI Audio...
After that is done, please install the latest driver from our Intel website, you can download it at the following link:
https://downloadcenter.intel.com/download/25698/Intel-HD-Graphics-Driver-for-Windows-7-8-1-10-3rd-Gen-BYT- Download Intel® HD Graphics Driver for Windows 7*, 8.1*, 10 (3rd Gen & BYT)
If this driver cannot be installed or you still have the same problem is probably because you have a customized driver in your system and it will not support our generic driver version, you will need to contact your system manufacturer for further assistance and to get the latest driver available from their website.
Please bear in mind that Intel provides generic versions of drivers for general purposes. Your http://www.intel.com/content/www/us/en/support/topics/oems.html computer manufacturer may have altered the features, incorporated customizations, or made other changes to your driver. Intel recommends you contact your computer manufacturer for the latest system specific updates and technical support information.
Ivan
JMend13
Thanks a lot for the help !
Have a nice day.
IUman
