23854 Discussions
Display error with YV12 textures
Vlad_Z_
System Used: N/A
CPU SKU: i5
GPU SKU: HD4600
Processor Line: N/A
System BIOS Version: N/A
CMOS settings: N/A
Graphics Driver Version: 10.18.14.4264
GOP/VBIOS Version: N/A
Operating System: windows
OS Version: 8.1 64bit
API: Directx9
Occurs on non-Intel GPUs?: N/A
Steps to Reproduce:
1. Create a texture withe the following code:
g_pd3dDevice->CreateTexture(uintWidth, uintHeight, 1, D3DUSAGE_DYNAMIC, (D3DFORMAT)MAKEFOURCC('Y', 'V', '1', '2'), D3DPOOL_DEFAULT, &g_pTexture, NULL);
2. Copy into the texture(after locking, of course) some raw pixel data:
	D3DLOCKED_RECT d3dlr;
	if (FAILED(g_pTexture->LockRect(0, &d3dlr, 0, D3DLOCK_DISCARD)))
		return;
	BYTE *pTxtBuffer; //texture buffer
	pTxtBuffer = static_cast<BYTE *>(d3dlr.pBits);
	memcpy(pTxtBuffer, buff, len);
	if (FAILED(g_pTexture->UnlockRect(0)))
		return;
3. Try to render it.
4.
5.
6.
7.
8.
9.
10.
Expected Results:
The image should display normally.
Actual Results:
The Y plane seems ok, but the color is red
Additional Information:
I'm aware that a color conversion is possible, but the d3d documentation states that if a driver accepts the MAKEFOURCC value, which it does, it should work.
screenshot of a comparison is attached. On the left is via a YV12 texture on the right is via directshow graph.
492329
Michael_C_Intel2
Hi Vlad,
We will investigate and see what is going on. We may need some information I will let you know if we do.
-Michael
