Todas vezes que tento atualizar a ferramenta diz opa! Alguma coisa deu errado durante a varredura.
E não consigo achar os drivers manualmente.
Processador: Intel(R) Pentium(R) 4 CPU 3.00 Ghz 3.02 Ghz.
- Tags:
- Drivers
Clear your browser cache and try again.
What OS are you using? Be very specific.
More information need to identify your processor.
Also, it is very unlikely that you will find what you want with IDSA.
Doc
If you haven't made a typo and you really have a Pentium 4 processor, then you should NOT be using IDSA. It is not designed to support processors or motherboards this old.
None of the packages that IDSA handles are going to help you anyway. The base drivers you need were loaded as part of the Windows 7 install and any updates to them will come via Windows Update. With a PC this old, you don't need anything else.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
