23481 Discussions
-NEW- 15.40.7.4279: Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 7, 8.1, 10
Bryce__Intel
Note: Operating system support varies by platform. Due to this and a limitation of the database, Download Center search capabilities cannot report OS support accurately, so please see the support information below or reference the associated https://downloadcenter.intel.com/download/25274 ReadMe's for more details.
The Windows 10* production driver https://downloadcenter.intel.com/download/25274 15.40.7.4279 has been posted to Intel Download Center at the following direct links to the driver:
This driver is in self installing format (exe) intended for end users.
32bit - https://downloadcenter.intel.com/downloads/eula/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10?httpDown=https://downloadmirror.intel.com/25274/eng/win32_15407.4279.exe win32_15407.4279.exe
64bit - https://downloadcenter.intel.com/downloads/eula/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10?httpDown=https://downloadmirror.intel.com/25274/eng/win64_15407.4279.exe win64_15407.4279.exe
This driver is in zip format intended for developers and IT professionals.
32bit - https://downloadcenter.intel.com/downloads/eula/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10?httpDown=https://downloadmirror.intel.com/25274/eng/win32_15407.4279.zip win32_15407.4279.zip
64bit - https://downloadcenter.intel.com/downloads/eula/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10?httpDown=https://downloadmirror.intel.com/25274/eng/win64_15407.4279.zip win64_15407.4279.zip
https://downloadmirror.intel.com/25274/eng/readme32.txt Read Me 32bit
https://downloadmirror.intel.com/25274/eng/readme64.txt Read Me 64bit
https://downloadcenter.intel.com/download/25274 https://downloadcenter.intel.com/download/25274
32bit support64bit support
6th Gen Intel(R) Core(TM) processor family
Microsoft Windows* 7
5th Generation Intel(R) Core(TM) processor family
Microsoft Windows* 8
Microsoft Windows* 8.1
4th Generation Intel(R) Core(TM) processor family
Microsoft Windows* 10
IMPORTANT:
These software drivers are generic versions and can be used for general purposes. However, computer original equipment manufacturers (OEMs) may have altered the features, incorporated customizations, or made other changes to the software or software packaging they provide which contain fixes specific to the OEM hardware the driver is intended for. To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer. Intel and the computer original equipment manufacturer (OEM) may not provide technical support for some or all issues that could arise from the usage of this generic version of software drivers.
Please review the https://downloadmirror.intel.com/25150/eng/ReleaseNotes_GFX_15%2040%204%2064%204256_8_5_15_Win10.pdf Release Notes for more information regarding this release.
Reporting Issues/feedback:
We continuously strive to improve the quality of our products to better serve our users and appreciate feedback on any issues you discover and <a href="http://communities.intel.com/community/tech/graphics/" rel="nofollow" target="_bl...
JKosi
On NUC5I5RYK, installer failed with the error attached.
Bryce__Intel
Found the error. I'm re-upping new files.
In the meantime, I verified that the zip files install correctly using setup.exe.
Allan_J_Intel1
sclaws
I have tested downloading and installing exe and zip drivers on same NUC model, I have been able to install the latest graphics driver version 4279.
Allan.
RCarl6
Will the "custom resolution exceeds the maximum bandwidth capacity" ever be fixed for custom resolution?
more info regarding the problem at
SBrea1
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue AND 'does it fail every single time, or only sometimes?' If you can offer a % rate please do.
Using WiDi to project a duplicated screen onto a 4K television, and the display isn't scaled to fill the entirety of the screen
Hardware (HW)
Brand and Model of the system.
Sony VAIO Tap 11
Hybrid or switchable graphics system? ie Does it have AMD or NV graphics too?
Intel HD Graphics 4200
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
EFP (projected via WiDi)
How much memory [RAM] in the system (see note2 below).
4GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
None
Hardware Stepping (see note1 below).
PCI/VEN_8086&DEV_0A1E&SUBSYS_90BB104D&REV_0B
PCI/VEN_8086&DEV_0A1E&CC_030000
Software (SW)
Operating System version (see note2 below).
Windows 10 Home
VBIOS (video BIOS) version. This can be found in "information page" of CUI (right click on Desktop and select "Graphics Properties".
Allan_J_Intel1
seemebreakthis
I have followed the steps you have provided on the sticky form. I am unable to replicate same problem.
I was able to project screen using my laptop with HD 4600 graphics and 4k monitor. The screen looks great.
I will try to ping the engineering department to see if they have seen same situation.
Allan.
SBrea1
Hello Allan,
Did you try setting the projected screen to different resolutions? At 1920 x 1080, at least over here there is definitely a problem (just a hint: to enable changing to a different resolution on the WiDi display u need to switch from 'duplicated display' to 'extended'). The exact same machine running Win8 (I have a dual boot config) with latest Intel display driver is running fine on 1920 x 1080.
Thank u.
rambomhtri
New Contributor II
I have 2 laptops:
Windows 8.1 x64 laptop with an i7-4700MQ fails to install this new driver. I've tried it using the x64 exe and zip. In both of them it says "this PC does not have the minimum requirements".
Windows 10 x64 laptop with also an i7-4700MQ fails to install using the exe, but the zip works, or at least gets installed without errors and the version is updated. Nevertheless, I found this issue. When I updated the driver using the zip, the blurry letters in "Device Manager" disappeared. But when I restarted the laptop, they came back. So it's still blurry, as well as many windows, options and menus in Windows 10. This is incredibly annoying.
So please, fix the 8.1 x64 version, and fix blurry letters in Windows 10 as well.
Allan_J_Intel1
rambomhtri
I just installed exe file of driver version 4279 on Intel® HD Graphics 4600, I did not get any issues through the installation.
Allan.
GDe_L5
Still problem with my monitor iiyama ProLite X2382HS.
Category
Questions
Description
98% of the time I turn off and on my monitor,
drivers crash and Windows 10 reboots. 2% the display driver fails but I return to the desktop
Hardware (HW)
CPU: Intel i5 4440S
GPU:Intel HD 4600
No.
EFP
<p style="f...
Allan_J_Intel1
I have been testing several monitors with different graphics controllers on Windows 10. I did not experience same situation you have described.
The computers I tried did not crash and I did not get any issue related to the graphics driver or graphics controller.
Allan.
AKuma91
The color darkening and fuzzy texture still remains in this driver.
The workaround still works, but I think an official solution will be better.
VŠ
Hello, my problem with BSOD is still there.
Category
Questions
Description
Everytime i put laptop into sleep mode and wake it up i get BSOD "video_scheduler_internal_error"
It happens only when i have video memory higher than 256mb. Same problem with previous version of video driver.
Hardware (HW)
i5-4210M,
HD4600
NO
sometimes both
8gb
PCI\VEN_8086&DEV_0416&SUBSYS_1993103C&REV_06
PCI\VEN_8086&DEV_0416&CC_030000
Software (SW)
Win 10 64bit
ralve1
this driver still have the same issues on intel hd graphics 530.
grid 2- the game in the loading screen crash to desktop no mater what you do
smite-still have multicolored pixels
grand theft auto v the crash as been fixed@ but memory runs out and received a warning
PLaur4
it`s not working on windows 8.1 ... please fix this (intel hd graphics 4400)
rambomhtri
New Contributor II
Neither on Windows 8.1 AND Windows 10 x64 with Intel HD 4600 of an i7-4700MQ (only zip works in Windows 10). Will Intel ever release again a graphics driver that has no problems? I don't think so. Last one had a non-working link, previous one had the same issue, now this... Come on!
PLaur4
rambomhtri
New Contributor II
You don't have to think, I'm telling you it doesn't work cause I'm trying it myself.
Bryce__Intel
rambomhtri, JabbaSenior, et al with HSW...
Note: Operating system support varies by platform. Please see the associated https://downloadcenter.intel.com/download/25274 ReadMe's for more details.
Edit: I updated the thread post adding a support matrix which details what's in the Readme for quick reference.
Your platform is not supported for Win8.1 with this driver, look for a '15.36' driver instead.For Win10, the exe's were corrupted. I've replaced them and verified they're working. If you need the exe, please redownload.
Hi Bryce@Intel,
are there any plans for a unified driver for Gen4/Gen5/Gen6 + Win7/8/10?
I am working for an OEM and our automated hardware detection/driver installation just work terrible when a driver has varying platform support.
Also if i filter in the download center for grafics driver "HD4600" and "Windows 8.1" i get the link to this driver which does not work for 8.1.
