23481 Discussions
-NEW- 15.40.7.4279: Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 7, 8.1, 10
Bryce__Intel
Note: Operating system support varies by platform. Due to this and a limitation of the database, Download Center search capabilities cannot report OS support accurately, so please see the support information below or reference the associated https://downloadcenter.intel.com/download/25274 ReadMe's for more details.
The Windows 10* production driver https://downloadcenter.intel.com/download/25274 15.40.7.4279 has been posted to Intel Download Center at the following direct links to the driver:
This driver is in self installing format (exe) intended for end users.
32bit - https://downloadcenter.intel.com/downloads/eula/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10?httpDown=https://downloadmirror.intel.com/25274/eng/win32_15407.4279.exe win32_15407.4279.exe
64bit - https://downloadcenter.intel.com/downloads/eula/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10?httpDown=https://downloadmirror.intel.com/25274/eng/win64_15407.4279.exe win64_15407.4279.exe
This driver is in zip format intended for developers and IT professionals.
32bit - https://downloadcenter.intel.com/downloads/eula/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10?httpDown=https://downloadmirror.intel.com/25274/eng/win32_15407.4279.zip win32_15407.4279.zip
64bit - https://downloadcenter.intel.com/downloads/eula/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10?httpDown=https://downloadmirror.intel.com/25274/eng/win64_15407.4279.zip win64_15407.4279.zip
https://downloadmirror.intel.com/25274/eng/readme32.txt Read Me 32bit
https://downloadmirror.intel.com/25274/eng/readme64.txt Read Me 64bit
https://downloadcenter.intel.com/download/25274 https://downloadcenter.intel.com/download/25274
32bit support64bit support
6th Gen Intel(R) Core(TM) processor family
Microsoft Windows* 7
5th Generation Intel(R) Core(TM) processor family
Microsoft Windows* 8
Microsoft Windows* 8.1
4th Generation Intel(R) Core(TM) processor family
Microsoft Windows* 10
IMPORTANT:
These software drivers are generic versions and can be used for general purposes. However, computer original equipment manufacturers (OEMs) may have altered the features, incorporated customizations, or made other changes to the software or software packaging they provide which contain fixes specific to the OEM hardware the driver is intended for. To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer. Intel and the computer original equipment manufacturer (OEM) may not provide technical support for some or all issues that could arise from the usage of this generic version of software drivers.
Please review the https://downloadmirror.intel.com/25150/eng/ReleaseNotes_GFX_15%2040%204%2064%204256_8_5_15_Win10.pdf Release Notes for more information regarding this release.
Reporting Issues/feedback:
We continuously strive to improve the quality of our products to better serve our users and appreciate feedback on any issues you discover and <a href="http://communities.intel.com/community/tech/graphics/" rel="nofollow" target="_bl...
AHoch
Hi Allan,
The last driver version I've been running on Windows 8.1 was 15.36.23.64.4251. It had CMAA working in Direct3D 9, as did one or two releases before that. Switching mid-August to Windows 10 Pro and 15.40.4.64.4256 immediately broke the CMAA. Note that the crash doesn't occur as soon as D3D9 device is created or geometry rendering starts. Sometimes it manages to run for several seconds before blowing, in which time I see that CMAA does indeed work. Oh, and windowed/full-screen mode also doesn't matter. Hope this helps.
There was a typo in my system's spec: it's i7 4770.
Alex
MVare2
Come on Intel, any official word on this matter regarding the HD Graphics in Skylake processors?
I just had to restart my PC the hard way since it frooze completely due to an ad on the internet.. And even on Firefox the graphics driver crashes, although much less frequently than on Edge or Internet Explorer.
Even on Windows 10 itself (not associated with a specific app or program), the lack of optimization on the graphics driver is noticeable - see the following image of the Busy cursor, it is not smooth, its edges are all pixelated - I have this since I installed Windows 10 on this PC with this processor...
dye1
firefox still causes graphics driver crash (i7 6700k)
ZTrze
HDMI Audio passthrough still failing for me.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue AND 'does it fail every single time, or only sometimes?' If you can offer a % rate please do.
Media playing software (e.g. Plex Home Theater) is able to pass the encoded audio (DTS/AC3) to AV receiver through HDMI only for the first initialized Windows user session. It no longer works for another logged in user, after logging in via RDP and then re-logging in locally, etc. Happens every time.
Hardware (HW)
Brand and Model of the system.
Intel NUC D54250WYKH
Hybrid or switchable graphics system? ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP - None
EFP - Sony TV via Yamaha AV Receiver
How much memory [RAM] in the system (see note2 below).
16GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
NUC HDMI -> Yamaha RX-V777 HDMI -> Sony TV
Hardware Stepping (see note1 below).
attached
Software (SW)
Operating System version (see note2 below).
Windows 10 Pro x64
attached<td style="border: none; padding: 0 5.4pt 0 5.4pt; border-right: solid windowtext 1.0pt; border-bottom: solid windowtext 1.0pt; border-left: none; border-top...
BW1
Category
Questions
Description
100% Can't install HD Graphics Drivers 15.40.7.4279
no matter exe or zip
Hardware (HW)
HP Envy M7-J120DX Laptop
No
LFP
<td style="padding-right: 4px; padding-left: 4px; borde...
Allan_J_Intel1
bin456789
Were you able to install the graphics driver 4279?
Did you try installing drivers manually?
http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
Download the zip version here: https://downloadcenter.intel.com/download/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10 Download Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows® 7, 8.1, & 10
Allan.
MGagl1
Is anybody still having the scaling problem with Intel HD 4600 and Windows 10?
Category
Questions
Description
Provide a detailed description of the issue AND'does it fail every single time, or only sometimes?' If you can offer a % rate please do.
Scaling option does not remain the same when running a game. EX. I run CSGO at 1024x758 and he scaling option changes itself back to Maintain Ascept Ratio even when I had selected Scale to full screen. This issue causes me to play with black bars instead of a stretched resolution.
Issue occurs with any 4:3 resolution
Hardware (HW)
Lenovo Y50-70 Touch
Intel and Nvidia
Intel HD 4600
Nvidia GTX 960M 4GB
16 GB
<tr style="border: 0px; font-we...
Allan_J_Intel1
egher
Category
Questions
Description
Screen starts flickering if the laptop power state changes (e.g. unplugged) or after the laptop is waken up from Suspension.
The only workarounds are:
1. reboot PC
2. manually restard video driver with the following command: devcon.exe restart "PCI\CC_0300"
Hardware (HW)
Dell XPS 13 9343
No
LFP
<td style="padding-right: 4px...
Allan_J_Intel1
ghepa
I've been testing same graphics controller model with driver version 4279. I followed the steps you mentioned but my computer did not start to flicker.
Allan.
egher
Hello Allan,
just leave your pc and let the PC turn off screen, and maybe go in Suspend mode.
After you wake up your PC, it starts flickering.
As soon as I get time I will post a video on youtube so you can see.
AStec
This is the most stable driver I installed since Windows 7 days! Before this release, I could not open Photoshop without HD driver immediately crashing. Also, after installing Windows 10 64 bit every day became a torment of blue screens (VIDEO_SCHEDULER_INTERNAL_ERROR) or driver crash after initializing graphics intensive apps including the not so intensive Google Maps and media players. None of these problems happened again since sep 9.
dcorr3
please read, an help me! win 10 intel hd 5500
gbhj
some improvements that can be made to Intel drivers:
  1. include an option to install http://raptr.com/intel Download Raptr Desktop App - Raptr this could also allow some of the game fixes that are writen into the driver to be moved to raptr (like Nvidia and AMD)
  2. the status of bugs needs to be more clearley displayed in the forum e.g fixed, wont-fix, in-progress , reported and not-reported
  3. when the driver are built can the product name field be updated (e.g it looks bad having windows 8 when the user could be on windows 7 or 10) the same goes for the copyright (still says 2014)
  1. there are games that detect the render device name (e.g does it contain the word Intel) is there a list of games that disable options because the of the render device name
an example of this is zuma's revenge that displays errors when enabling hardware acceleration or HD (changing the name of the render device allows the game to work in HD)
JKosi
Category
Questions
Description
Frame drops seen playing back any video file every 3-4 minutes. Happens 100% of the time.
Hardware (HW)
NUC 5I5RYK
No and no.
EFP. A Vizio M801D-A3 HDTV.
16GB
<td style="padding: 0 5.4pt; border-width: 0px 1pt 1pt 0px; border-style: none solid solid none; border-right-color: windowtext; border-bottom-color: windowtex...
PSaha1
Category
Questions
Description
Black Screen After Graphics Driver Installed and after reboot. Fails to turn on display 100% of the time.
Hardware (HW)
Acer C720
No. Integrated only.
LFP over eDP
<p align="center" style="font-weight: inhe...
PPock
Much like coolstar above i have the same exact problem on the same exact device on windows 10 pro, it doesn't work, I also use teamviewer to access it, it detects no display devices after the driver installation.
VN3
I have same issue like @coolstar . Windows 10 SL, Intel HD 4600 + NVidia GF 750m. No display detected. Very annoying.
AFedc
Category
Questions
Description
Everytime when PC is waking-up from sleep mode the Windows is going to BSOD with VIDEO_SCHEDULER_INTERNAL_ERROR error
Hardware (HW)
Custom assembled PC
Only integrated graphics.
Single EFP - Dell U2412M connected through DVI interface
<span style="color: # 3d3d3d; font-family: intel-clear, arial, helvetica, 'helvetica neue', verdana, sans-serif; font-size: 13px; text-align:...
gbhj
the first game i have had problems with is bejeweled 2 no allowing hardware acceleration to be enabled enabling hardware acceleration improves the visual quality of the game and allows the game to automatically enable the high resolution option.
the next game is bejeweled 3 this game requires 3D acceleration for higher resolution to be enabled
the next game is bejeweled twist that requires 3D acceleration for higher resolution to be enabled and other game settings
the next game is plants vs zombies that requires 3D acceleration for improved visual quality
the next game is zuma deluxe that that requires 3D acceleration for improved visual quality
the next game peggle that requires 3D acceleration for improved visual quality
the last game is peggle nights that requires 3D acceleration for improved visual quality
all of the above will allow 3D acceleration to be enabled when the Intel driver is removed
PSill
New User
Latest graphics driver has quite a few problems.
New build
Windows 10
Intel 6700k processor
64gb of RAM
Display Port
2560x1600 resolution
Crashes when scrolling in either Facebook or YouTube. Result in vertical blue and green lines on screen. Can access Task Manager and reboot system using CTRL-ALT-DELETE. Can not get back to desktop. This does not happen in a standard web-page and must have something to do with video on web-sites. Also, noticed fluctuations in the LUT mapping when scrolling on these sites prior to the crash.
It seems that this is a problem with web-sites that embed video in a certain way. Others do not exhibit this issue.
Adobe - Camera RAW 9.1 does not work with graphics acceleration checked. Presents a yellow rectangle instead of the image decoded from RAW.
So far the processor seems wonderful, however will probably need to go with dedicated graphics (don't want to) unless the above issues are checked.
