23054 討論
-NEW- Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 10 64-bit 15.40.4.64.4256
Bryce__Intel
員工
145,566 檢視
The Windows 10* production driver 15.40.4.64.4256 has been posted to Intel Download Center at the following direct link to the driver:
64bit - https://downloadcenter.intel.com/downloads/eula/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit?httpDown=http://downloadmirror.intel.com/25150/eng/win64_154004.2.exe win64_154004.2.exe - This driver is in self installing format intended for end users.
64bit - https://downloadcenter.intel.com/downloads/eula/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit?httpDown=http://downloadmirror.intel.com/25150/eng/win64_154004.2.zip win64_154004.2.zip - This driver is in zip format intended for developers and IT professionals.
https://downloadcenter.intel.com/download/25150 https://downloadcenter.intel.com/download/25150
IMPORTANT:
These software drivers are generic versions and can be used for general purposes. However, computer original equipment manufacturers (OEMs) may have altered the features, incorporated customizations, or made other changes to the software or software packaging they provide which contain fixes specific to the OEM hardware the driver is intended for. To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer. Intel and the computer original equipment manufacturer (OEM) may not provide technical support for some or all issues that could arise from the usage of this generic version of software drivers.
Please review the https://downloadmirror.intel.com/25150/eng/ReleaseNotes_GFX_15%2040%204%2064%204256_8_5_15_Win10.pdf Release Notes for more information regarding this release.
Reporting Issues/feedback:
We continuously strive to improve the quality of our products to better serve our users and appreciate feedback on any issues you discover and http://communities.intel.com/community/tech/graphics/ suggestions for future driver releases. If you have an issue to submit, please follow the guidance/process in this sticky .
*Other names and brands may be claimed as the property of others.
Other Windows 10 Resources:
http://www.intel.com/support/win10.htm Support information about Intel products and Windows® 10
http://www.microsoft.com/en-us/windows/Windows-10-faq# ui-id-23 Windows 10 FAQ & Tips - Microsoft
206 回應
Bryce__Intel
員工
11,243 檢視
Hi all,
Just alerting everyone that the driver posted has been updated to include support for the latest 6th Generation Intel® Core™ processors, the original post here has been updated to reflect this as well. I modified the filenames to differentiate between this new version. This is essentially the same driver as before, so if you already downloaded it for your HSW/BDW systems, there's NO need to download/install it again. Just a heads up FYI.
MSchm21
傑出貢獻者 I
11,243 檢視
Business as usual:
The page you requested has moved or doesn't exist. (Error 404)
Intel can't get a simple download page right, how pathetic is this. Who is responsible for the mess? Intel should fire those.
SBren4
初學者
11,243 檢視
This driver is worse than the last one. It sill won't detect my 3rd monitor, which is a problem Intel still hasn't solved. But even worse, I can't reinstall or even reset the driver without my middle monitor spazzing up and flashing colors.
AMoha25
初學者
11,243 檢視
Download links Broken
AKryp
初學者
11,243 檢視
Download links are definitely broken.
HPont
初學者
11,243 檢視
Broken links. It's very important to improve this drivers for Win10 because I can't play any game on fullscreen/window mode. Disabling Intel Graphics and keeping Nvidia enabled it works! But fps are reduced to 2.5 😕
KUri
初學者
11,243 檢視
The downloadlink is broken. Is there anywhere else we can download the new drivers?
DJenk3
新手
11,243 檢視
When I click on the link to download the file I get an "Error: Page Not Found." Please fix this.
After an upgrade to Windows 10 my Intel(R) HD Graphics 5500 device is telling me, "Windows has stopped this device because it has reported problems. (Code 43)
My driver details are:
Driver Provider: Intel Corporation
Driver Date: 6/29/2015
Driver Version: 10.18.15.4248
Digital Signer: Microsoft Windows Hardware Compatibility Publisher
Windows Update tells me I have the latest version, however when I check my wife's computer, she has a more recent version and we both have exactly the same laptop. (ASUS TP500L) I found the download for her version here, but get the page not found error whenever trying to download it.
VVive3
初學者
11,243 檢視
Hi
I have Intel HD Graphics 3000 running on a second generation core i5. Recently upgraded to Windows 10 64 bit. Is there an updated graphics driver?
The system is working fine except for a pause on resuming from sleep and while starting up!
Best regards
VS
MEnge1
初學者
11,243 檢視
I was able to download the newest driver by going to the mirror site and it was somewhere in an inprogress folder.
But for me it was not a solution to my problem.
I don't have any weird tearing effects but with my Dell 5440 with Intel HD 4400 when activating CMAA I cannot play any
game. The driver crashes (notification right below that it has stopped responding and has restarted).
When disabling CMAA and enabling MSAA (which I don't use in any game because it hurts framerate considerable with the 4400)
it plays fine, though the graphics are not that smooth (thats what I want to use CMAA for).
Also with CMAA enabled, Microsoft Edge is very blurry.
So for now it's CMAA off, MSAA on but I would really like to be able to use it again.
CWare1
新手
11,243 檢視
This driver not only doesn't fix or work on Windows 10, the link is actually broken at them moment.
mshi2
初學者
11,243 檢視
the link is broken.
mshi2
初學者
11,243 檢視
I found the link from reddit,
http://downloadmirror.intel.com/25150inprocess/eng/ downloadmirror-origin.intel.com - /25150inprocess/eng/
CWare1
新手
11,203 檢視
Nice work finding the link! Unfortunately, the drivers still don't work in Windows 10.
DJenk3
新手
11,203 檢視
Same issue for me. I was able to get the file at the link provided by maruko (Thanks, btw!), but they still give me the message that a problem was encountered and the device has been disabled. So frustrating.
CWare1
新手
11,203 檢視
The download says it is version 15.40.4.64.4256 yet when you install it, the version actually is 10.18.15.4256 as shown in this install screen. Whatever is being put out by Intel is simply wrong and needs to be corrected.
MEnge1
初學者
11,203 檢視
Tried with the official Dell E5440 graphic drivers (version 4248), but the same problem with enabling CMAA.
DJenk3
新手
11,203 檢視
My wife's laptop (which is identical to mine) somehow got these drivers during the Windows 10 upgrade. They seem to be working fine for her.
MSchm21
傑出貢獻者 I
11,203 檢視
There is no need for a correction because it is correct. 15.40.xx refers to the package version where other things like audio, OpenCL etc. are included, 10.18.xx refers to the graphics driver.
TNgo
初學者
11,203 檢視
error 404 when download. Please check the link again. Thank you.
MMill22
新手
11,203 檢視
Here's another nice graphics corruption while playing this video: https://www.youtube.com/watch?v=ECHLYTeq5Rs Fatal1ty vs Toxic WSVG 2006 Quake4 GrandFinals Full Video HD 1080p - YouTube
Green corruption on top. This happens with hardware accelerated Youtube video every once in a while. But the video doesn't really matter, it can happen in any video. It is not in the source, i checked.
And there is also still the issue about BSODs with DXVA accelerated video playback...
*** STOP: 0x00000116 (0xffffe001200ad160, 0xfffff800abc76550, 0x0000000000000000, 0x000000000000000d)
*** dxgkrnl.sys - Address 0xfffff800aad12a7c base at 0xfffff800aabd0000 DateStamp 0x55af128a
回覆
