公告
23491 討論
-NEW- Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 10 64-bit 15.40.4.64.4256
Bryce__Intel
員工
198,521 檢視
The Windows 10* production driver 15.40.4.64.4256 has been posted to Intel Download Center at the following direct link to the driver:
64bit - https://downloadcenter.intel.com/downloads/eula/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit?httpDown=http://downloadmirror.intel.com/25150/eng/win64_154004.2.exe win64_154004.2.exe - This driver is in self installing format intended for end users.
64bit - https://downloadcenter.intel.com/downloads/eula/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit?httpDown=http://downloadmirror.intel.com/25150/eng/win64_154004.2.zip win64_154004.2.zip - This driver is in zip format intended for developers and IT professionals.
https://downloadcenter.intel.com/download/25150 https://downloadcenter.intel.com/download/25150
IMPORTANT:
These software drivers are generic versions and can be used for general purposes. However, computer original equipment manufacturers (OEMs) may have altered the features, incorporated customizations, or made other changes to the software or software packaging they provide which contain fixes specific to the OEM hardware the driver is intended for. To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer. Intel and the computer original equipment manufacturer (OEM) may not provide technical support for some or all issues that could arise from the usage of this generic version of software drivers.
Please review the https://downloadmirror.intel.com/25150/eng/ReleaseNotes_GFX_15%2040%204%2064%204256_8_5_15_Win10.pdf Release Notes for more information regarding this release.
Reporting Issues/feedback:
We continuously strive to improve the quality of our products to better serve our users and appreciate feedback on any issues you discover and http://communities.intel.com/community/tech/graphics/ suggestions for future driver releases. If you have an issue to submit, please follow the guidance/process in this sticky .
*Other names and brands may be claimed as the property of others.
Other Windows 10 Resources:
http://www.intel.com/support/win10.htm Support information about Intel products and Windows® 10
http://www.microsoft.com/en-us/windows/Windows-10-faq# ui-id-23 Windows 10 FAQ & Tips - Microsoft
206 回應
GCopp2
初學者
31,151 檢視
Intel Core i5-4210H 2x2.9Ghz
8GB DDR3-1600 MHz
nVidia GeForce GT840M
Intel HD 4600
Windows 10 Issues
Hi. After my Windows 10 Upgrade, I decided to install the "Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 10 64-bit".
This driver also causes this issue that videos have graphics issues, have a look into "-1-.bmp" , and in the internet also, the rest of an internet site gets lost, have a look into "-2-.bmp".
Installed various drivers, same results..
Internet issues also on W 8.1
GCopp2
初學者
31,150 檢視
MMill22
新手
29,852 檢視
I've now also had some video corruption with these drivers, playing a HTML5 Youtube video (hardware accelerated). The artefacts looked a lot like this previously posted image:
GianCist schrieb:
They were also mostly at the top, and green artefacts. This also happens rarely, you will have to watch Youtube for quite some time, but then for one or two seconds you get this green stuff. When you rewind, it's not there anymore, proving that it was not in the source video.
Allan_J_Intel1
29,785 檢視
GianCist
I understand the Intel engineering team is working to resolve this as quickly as possible. Please be sure to fill out this information as complete as possible.
[copy and paste it to a new thread OR within an existing thread 'reply' and copy+paste this to fill in]
Allan.
MHill10
新手
31,150 檢視
This production driver appears to be riddled with the same installation headaches and incompatibility issues that plagued the beta drivers. I'm getting the same issue, where windows 10 is disabling the adapter/driver, and not allowing the Intel control panel to be run. I've tried about a dozen different combinations of installation order/method, all with the same results.
Error 43 in device manager.
AMay2
初學者
31,150 檢視
I have the exact same issue
MHill10
新手
31,150 檢視
The installer package says version 15.whatever, but the actual installer program appears to be installing 10.18.15.4256. Please advise.
Allan_J_Intel1
31,150 檢視
Drivers are often referred to by either build number or driver version. Please take a look at the information about graphics driver version numbers:
http://www.intel.com/support/graphics/sb/CS-020667.htm Graphics Drivers — Understanding The Intel® Graphics Driver Version Number
Allan.
AFedc
新手
31,150 檢視
I have HD4600 GPU and seems this driver causes BSOD (VIDEO_SCHEDULER_INTERNAL_ERROR) during wake-up PC.
Here is archive with a few crash dumps https://onedrive.live.com/redir?resid=C3F8BA2FB83BBD05!28393&authkey=!AJIDGec-uPbhWAE&ithint=file%2czip intel_hd_4600_15.40.4.64.4256_dumps.
VŠ
新手
29,852 檢視
Hi, i have a same problem here. Same graphic card and after upgrade to Win 10 and wakind up from sleep i get this BSOD (VIDEO_SCHEDULER_INTERNAL_ERROR).
fjouh
新手
29,812 檢視
Try to switch memory size to 128MB in bios (it was set to 512MB before). It's helps me, no more BSOD now !
Let's know us if it works for you too !
VŠ
新手
29,812 檢視
I have switched it to 256 and it helps, thanks for advice. But if they doesnt fix it soon, i will downgrade back to 8.1, becouse i want to use all possible memory (512mb) not just part of it.
TMill10
初學者
29,812 檢視
This is the working solution for now. Guess we'll have to wait for a fixed driver.
Allan_J_Intel1
29,785 檢視
nightik
I am trying to replicate this issue, can you be sure to fill out this information as complete as possible?
[Copy and paste it to a new thread OR within an existing thread 'reply' and copy+paste this to fill in]
Allan.
AFedc
新手
29,795 檢視
Hi, @allan_intel.
Se the requested information below.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue AND 'does it fail every single time, or only sometimes?' If you can offer a % rate please do.
Everytime when PC is waking-up from sleep mode the Windows is going to BSOD with VIDEO_SCHEDULER_INTERNAL_ERROR error
Hardware (HW)
Brand and Model of the system.
Custom assembled PC
Hybrid or switchable graphics system? ie Does it have AMD or NV graphics too?
Only integrated graphics.
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
Single EFP - Dell U2412M connected through DVI interface
attached<p style="font-weight: inherit; font-style: inherit;"...
EMosh
初學者
29,794 檢視
nightik
Hi there, I just wanted to let you know that there is a new driver. If you run windows update you should be able to get version 10.18.15.4281. Looking at your build you are on build 4256. Try to upgrade and see if this disappears. At least for me the DirectX screensaver issue was resolved. If you still got problem please let us know.
AFedc
新手
29,794 檢視
Feejus, thanks for suggestion. But from WU I've received only 10.18.15.4279 driver which has exactly same issue with sleep mode. I'll post detailed info at the particular thread.
EMosh
初學者
29,794 檢視
Hi nightik,
I think i know why now. I am on Fast Ring and on the beta, that might be the reason i got the newer version of the driver! I am sure someone here is able to help you to get hold of the build above. I had the same issue but that seems to be resolved with 4281.
Thank you
Feejus
MHasa5
新貢獻者 I
29,794 檢視
Nightik download WhoCrashed from Cnet then update it. It tells you what caused it look at my results
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Thu 15/10/2015 16:56:57 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\101515-22875-01.dmp
This was probably caused by the following module: http://www.google.com/search?q=watchdog.sys watchdog.sys (watchdog+0x3C3D)
Bugcheck code: 0x119 (0x1, 0x11386E, 0x11386F, 0xFFFFE0014A6E23B0)
Error: http://www.google.com/search?q=MSDN+bugcheck+VIDEO_SCHEDULER_INTERNAL_ERROR VIDEO_SCHEDULER_INTERNAL_ERROR
file path: C:\WINDOWS\system32\drivers\watchdog.sys
product: http://www.google.com/search?q=Microsoft® Windows® Operating System Microsoft® Windows® Operating System
company: http://www.google.com/search?q=Microsoft Corporation Microsoft Corporation
description: Watchdog Driver
Bug check description: This indicates that the video scheduler has detected a fatal violation.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: http://www.google.com/search?q=watchdog.sys watchdog.sys (watchdog!WdLogEvent5_WdCriticalError+0xCD)
On Sun 11/10/2015 15:58:18 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\101115-21125-01.dmp
This was probably caused by the following module: http://www.google.com/search?q=igdkmd64.sys igdkmd64.sys (igdkmd64+0x16560)
Bugcheck code: 0x116 (0xFFFFE000691204C0, 0xFFFFF80023926560, 0x0, 0xD)
Error: http://www.google.com/search?q=MSDN+bugcheck+VIDEO_TDR_ERROR VIDEO_TDR_ERROR
file path: C:\WINDOWS\system32\drivers\igdkmd64.sys
product: http://www.google.com/search?q=Intel HD Graphics Drivers for Windows 8(R) Intel HD Graphics Drivers for Windows 8(R)
company: http://www.google.com/search?q=Intel Corporation Intel Corporation
description: Intel Graphics Kernel Mode Driver
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: igdkmd64.sys (Intel Graphics Kernel Mode Driver, Intel Corporation).
Google query: http://www.google.com/search?q=igdkmd64.sys+Intel Corporation+VIDEO_TDR_ERROR Intel Corporation VIDEO_TDR_ERROR
I too have got that error but somehow it stop and dosen't happen anymore . Download DDU then go to safe mode uninstall the driver you are using then try downloading again. That stop the BSOD for me but I still do get driver crashes everything on my laptop is UP TO DATE. Everything... except intel management interface because the latest one v11 causes black screen/crash after awaken from sleep mode. If you do get the black screen roll back to v9 using device manager. Keep up the "GOOD" work Intel on drivers!
This is the problem I get my chipset drivers are up to date. Also it says Win8(R) im using win10 there maybe was a glitch or problem with the upgrade ??
TRans
新手
31,150 檢視
I believe there is a problem with this driver on the Microsoft Surface Pro 3- under the Intel Graphics Control Panel Custom Resolutions, the Timing Standard option is no longer present. It is therefore currently impossible to add a custom 3840x2160@50Hz resolution (as was possible in Windows 8.1 with the latest Windows 8 Intel driver) as all options exceed the available display bandwidth.
Ref. my other post here with full details:
回覆
