23481 Discussions
-NEW- Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 10 64-bit 15.40.4.64.4256
Bryce__Intel
The Windows 10* production driver 15.40.4.64.4256 has been posted to Intel Download Center at the following direct link to the driver:
64bit - https://downloadcenter.intel.com/downloads/eula/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit?httpDown=http://downloadmirror.intel.com/25150/eng/win64_154004.2.exe win64_154004.2.exe - This driver is in self installing format intended for end users.
64bit - https://downloadcenter.intel.com/downloads/eula/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit?httpDown=http://downloadmirror.intel.com/25150/eng/win64_154004.2.zip win64_154004.2.zip - This driver is in zip format intended for developers and IT professionals.
https://downloadcenter.intel.com/download/25150 https://downloadcenter.intel.com/download/25150
IMPORTANT:
These software drivers are generic versions and can be used for general purposes. However, computer original equipment manufacturers (OEMs) may have altered the features, incorporated customizations, or made other changes to the software or software packaging they provide which contain fixes specific to the OEM hardware the driver is intended for. To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer. Intel and the computer original equipment manufacturer (OEM) may not provide technical support for some or all issues that could arise from the usage of this generic version of software drivers.
Please review the https://downloadmirror.intel.com/25150/eng/ReleaseNotes_GFX_15%2040%204%2064%204256_8_5_15_Win10.pdf Release Notes for more information regarding this release.
Reporting Issues/feedback:
We continuously strive to improve the quality of our products to better serve our users and appreciate feedback on any issues you discover and http://communities.intel.com/community/tech/graphics/ suggestions for future driver releases. If you have an issue to submit, please follow the guidance/process in this sticky .
*Other names and brands may be claimed as the property of others.
Other Windows 10 Resources:
http://www.intel.com/support/win10.htm Support information about Intel products and Windows® 10
http://www.microsoft.com/en-us/windows/Windows-10-faq# ui-id-23 Windows 10 FAQ & Tips - Microsoft
Allan_J_Intel1
SebaDD
This is the latest graphics driver for Windows 10, please use the link below to download it.
https://downloadcenter.intel.com/download/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10 Intel® Download Center
Allan.
GDe_L5
Configuration:
CPU:Intel i5-4440S
GPU:Intel HD 4600 (Driver 15.40.4.64.4256)
Motherboard:MSI Z97 Gaming 7 (latest bios 1.A)
Monitor:iiyama ProLite X2382HS connected in HDMI
Problem:
Everytime I turn off and on the monitor(pressing the power button), the drivers crash and Win10 goes BSOD.
I had the same problem with Windows 8.1 Pro, before upgrading.
Please fix this problem in the next release! If you need more info, let me know.
Allan_J_Intel1
gdl
If you are still experiencing same graphics driver issue, even after downloading and installing the latest video drivers, please follow the guidance/process in this sticky
Here is the link for the latest video drivers:
Allan.
KShal
It looks like with drivers 4279 BSOD are gone. But i'm not sure yet.
KShal
I have one problem with 4279 driver. After ALT+TAB on previous driver was BSOD, now is not as i said in my previous message, but i've got error "display driver intel hd graphic drivers for windows 8 stopped responding and has successfully recovered"
Bryce__Intel
All,
We're working diligently to get through the list of issues and we greatly appreciate the support from the community thus far. Please keep in mind when you report a new concern, please provide the information requested in the sticky [link below]. This level of information helps replicate the issues and streamlines the process to get in front of an engineer. Thanks for your patience and those of you who have been answering questions, your assists are very appreciated, that's what truly makes this a community. If you notice someone who hasn't provided the necessary information, please help refer them to the sticky. Thanks!
Stay tuned...
MMill22
Hello Bryce@Intel,
i will report my BSODs in the proper way now.
Description - Bluescreens during hardware-accelerated video playback (DXVA)
Hardware and Software - see http://pastebin.com/n5vmSSk0 dxdiag.txt - Pastebin.com
Configuration - single display via DVI, 1920x1080
How to reproduce - Watching a video in a video player with DXVA acceleration, then it sporadically bluescreens. Not often, but it will happen.
Watching video with MPC-HC x86 (MPC Homecinema), which uses DXVA2 hardware acceleration (under "Output", select "Enhanced Video Renderer - Custom Presenter"). Suddenly the screen turns black and there is a sound as if a device was unplugged. The sound of the video keeps playing at first, but nothing on the screen. Then a few seconds later, the bluescreen.
*** STOP: 0x00000116 (0xffffe000f846f010, 0xfffff80121516550, 0x0000000000000000, 0x000000000000000d)
*** dxgkrnl.sys - Address 0xfffff80120202a7c base at 0xfffff801200c0000 DateStamp 0x55af128a
Second bluescreen:
*** STOP: 0x00000116 (0xffffe001200ad160, 0xfffff800abc76550, 0x0000000000000000, 0x000000000000000d)
*** dxgkrnl.sys - Address 0xfffff800aad12a7c base at 0xfffff800aabd0000 DateStamp 0x55af128a
It seems like Windows 10 noticed something wrong with how the driver behaves, tries (but fails) to restart the driver and then ultimately bluescreens.
Amy_C_Intel
Hello Mike500,
I performed a lab under these circumstances but I couldn't get the same issue reported, have you tried with the latest version https://downloadcenter.intel.com/download/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10 Download Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows® 7, 8.1, & 10?
Amy.
MMill22
Hello Amy_Intel, first of all, thanks for finally testing this. But i have moved on from Intel graphics to an NVIDIA GeForce 960 now. For weeks i had to watch videos with software playback because the Intel Windows 10 graphics drivers were so buggy. So now i've disabled the integrated graphics and i'm back on NVIDIA, couldn't be happier. Their drivers are great.
I don't know if this problem was solved with the newer driver, and frankly, i don't care anymore. I was very disappointed that Intel couldn't manage to write a proper driver in time for the Windows 10 launch. It's not like Win10 came out of the blue.
Thanks again for replying and good luck to all the Intel users, i hope Intel can get their stuff together with the driver quality.
Amy_C_Intel
I am glad to hear that you were able to resolve your issue. Your feedback is important to us and I thank you for taking the time to communicate this issue.
Amy.
MHasa5
I get BSOD errors and display driver hast stopped responding for WINDOWS 8.1(R) after 2 months after windows 10 upgrade
With all due respect Amy_Intel did you even read Mike500's post?
His issue is resolved because he's using another video card rather than the suffer any more with these terrible Intel drivers.
MHasa5
AGREED A TRILLION TIMES THESE DRIVERS ARE TERRIBLE! LOOK AT JUST HOW MANY PEOPLE ARE ANNOYED AND UNSATIFIED WITH THIS ISSUE. I contaced Microsoft (remote assistance live technical chat) they do not know how to fix the issue. Made like 6 forums (HP FORUMS) on Driver crashes and BSOD related to Graphic drivers NOT EVEN TRIED TO HELP and Intel? Make 2 graphic production driver whatever it is called and no differences made. THIS IS THE MOST ANNOYINNG ISSUE FOR ME ASWELL AS BSOD'S:
ALL MY DRIVERS EVERYTHING ARE UP - TO - DATE
AND WINDOWS 8.1(R) I AM USING WINDOWS 10
The latest Windows 10 video driver causes the windows on my Intel NUC to resize when resuming from sleep AGAIN.
This issue was resolved a few releases ago, but it's now back in the latest release. Great work Intel!
SBrea1
Category
Questions
<p align="center" style="margin: auto ...
Allan_J_Intel1
seemebreakthis
I have been testing the latest graphics drivers 4256 using Passmark's PerformanceTest 8.0 but I did not get any driver crash problems. I have followed step by step provided on your post.
Are you still getting same problem?
Allan.
Driver crash when you run a Passmark's PerformanceTest 8.0 3D DirectX 9 test (either one of the two)
1. Fire up PerformanceTest
2. Select 'Tests' -> 3D Graphics -> DirectX 9 – Simple
3. After a few seconds the system says 'display driver stopped working and has recovered'
SBrea1
allan_intel
Hello Allan,
Yes the same problem persists over here, can repro each time.
One thing I found however is that if I go to Intel HD Graphics Control Panel, "3D", then change the Convervative Morphological Anti-Aliasing settings from "Override Application Settings" to "Turn Off", the problem would vanish.
Amy_C_Intel
Hello seemebreakthis,
I downloaded the software mentioned and ran it on different computers under the same circumstances but the driver did not crash, I even tested it with the latest driver version and it worked.
Amy.
GDe_L5
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue AND whether it's consistent or sporadic.
Everytime I turn off and on the monitor I have a BSOD. I had the same problem with Windows 8.1 Pro before upgrading. I already tried different driver versions with no luck.
Hardware (HW)
Brand and Model of the system.
Motherboard: MSI Z97 GAMING 7 (MS-7916) (BIOS 1.A)
CPU: Intel Core i5-4440S
Hybrid or switchable graphics system?
Intel HD Graphics 4600
Make and model of any Displays that are used to see the issue (see note2 below).
iiyama ProLite X2380H Series (ProLite X2382HS)
How much memory in the system (see note2 below).
32768MB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
HDMI
Hardware Stepping (see note1 below).
<td style="border: 1px solid black; border-color: # 000000 windowtext windowtext # 000000; border-style: none solid solid none; border-width: 0px 1pt 1....
AWhit14
BSOD (VIDEO_SCHEDULER_INTERNAL_ERROR) after wake-up on this driver (Windows 10 64bit, Intel HD Grapichs 4400)
SYuan5
Category
Questions
Description
Provide a detailed description of the issue AND 'does it fail every single time, or only sometimes?' If you can offer a % rate please do.
Some Graphic issue and slow performance on windows 10 , 100% rate slowdown when goin 4k on browser and anything i do and video artefact.
Hardware (HW)
G501JW
Hybrid or switchable graphics system? ie Does it have AMD or NV graphics too?
Yes,Optimus
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP, never tested EFP.
How much memory [RAM] in the system (see note2 below).
<td style="padding-right: 4px; padding-left: 4px; border-right-width: 1pt; border-bottom-width: 1pt; border-style: none solid solid none; border-right-color:...
