23733 Discussions
NUC7i3BNB - Screen resolution issue
PMadh1
Hello
I just purchased the above nuc and installed Windows 10 with all the latest drivers.
I have noticed when when I lock the computer (Win+L) and gets back from lunch and logs back on again the display is reset to what looks like HD. All open windows are heavily minimized up in the left corner and all needs to be resized to my desktop resolution 2560 x 1440.
Is there a fix or workaround to fix this?
Hello Punster
Thank you for joining the community.
To have a better understanding of your system could you provide us with the following information?
The Intel® System Support Utility for Windows* report, please attach the report to the thread.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Leonardo C.
PMadh1
Hello and thanks for reply.
I downloaded and ran the SSU tool see attachment for the log.
Hello Punster
Thank you for your response.
I see that you have installed the driver version .4901 of the Intel® HD graphics 620; you can try to install the driver version .4944, you can find that at the following link.
https://downloadmirror.intel.com/27484/a08/win64_15.65.4.4944.exe https://downloadmirror.intel.com/27484/a08/win64_15.65.4.4944.exe
Also, verify that your Windows® 10 is up-to-date.
Leonardo C.
PMadh1
Hello
I downloaded and tried to install the driver you suggested but recieve this message during intallation...
Hello Punster
Could you let us know if the problem happens when your system goes into sleep mode and you wake it up?
For the driver update we can try to complete it following these steps:
1. Download the graphics driver ZIP file: https://downloadmirror.intel.com/27484/a08/win64_15.65.4.4944.zip https://downloadmirror.intel.com/27484/a08/win64_15.65.4.4944.zip
2. Unzip the file to a designated location or folder.
3. Right-click Windows Start icon and open Device Manager.
4. Click "Yes" when prompted for permission from User Account Control.
5. Expand the Display adapters section.
6. Right-click the Intel® graphics entry and select Update Driver Software.
7. Click "Browse my computer for driver software".
8. Click "Let me pick from a list of device drivers on my computer".
9. Click "Have Disk".
10. Click "Browse".
11. Access the designated location or folder, and access a folder called "Graphics".
12. Select the file called "igdlh64" or "igdlh".
13. Click Open, then click OK, and finally click "Next". Drivers are now being installed.
14. Reboot your computer.
And let me know if you have any issues with the installation.
Leonardo C.
PMadh1
Driver is now installed with latest version.
As I said in my opening post. If I lock the computer (Win+L) , go to lunch or is away from my computer some time. When I get back to wake up the display (there is no hibernate of the computer, but display is set to 1 hour inactivity timer). All programs are minimized to 1/4 of their size in the upper left corner of the screen.
This should be easy to simulate in a lab.
NUC7i3BNB + HDMI + Monitor resolution with 2560 x 1440 + Win10Pro X64 (pretty default settings) and all drivers/OS up-to-date.
Lock the computer and walk away for a few hours and get back.
Hello Punster
Allowed me to share with you this thread /thread/102871 https://communities.intel.com/thread/102871, we are currently investigation your situation in there, you can post your inquiry there, as soon as we have information on the matter we will be sharing that with you there.
Thank you.
Leonardo C.
PMadh1
Hello.
Just a quick update. I purchased a USB-C to Displayport cable to replace the HDMI cable and this solved my problem.
PMadh1
Hello
Guess I spoke too soon. Everything looked fine for a while. The NUC is overheating when using USB-C as display connection and refuses to start until it has cooled down.
Back to HDMI and same problem again.
Hello Punster
Thank you for the information.
To check the processor performance; could you provide us with the Intel® Processor Diagnostic Tool result? Please attach the result to the thread.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Regards.
Leonardo C.
PMadh1
Hello
I ran the tool. See attachment for log output.
Hello
Thank you for the response.
We see that your processor is working fine; to confirm with you if you use the NUC with the HDMI® you don't have the overheating situation?
Could you provide us with the model of the USB-C cable/dongle you were using?
Regards.
Leonardo C.
Hello Punster
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
