Have tried the Win7 945 and, tho it 'works' it does not really work well. Graphics only get a 1 rating in properties and none of the features work. Any ideas?? Please help!!
- Tags:
- 5G
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=939&lang=eng
I have found in this link, but there no driver support window 7 with this chipset.
Hi there,
Unfortunately most of the Windows 7 drivers provided by Intel are Beta versions only and are provided on an as-is basis meaning that there is not guarantee that they should work. Windows 7 Beta drivers are not available for most of the components. I assume when Windows 7 will officially be released, then Intel will make proper tested drivers for Windows 7 and could thereon provide support if people are having problems with the drives. At this stage it is difficult advise you which drivers to download as a work-around. You may try to use the same drivers you there are available for windows vista for your motherboard, it may work fine.
Hope this will be useful.
Cheers
Problem is that link does not even have Vista support. Any ideas on just a Vista driver for this chipset?? Thanks!
Hi, did you try the link offered in this post:
/message/105463# 105463 http://communities.intel.com/message/105463# 105463
I am currently testing it and it looks quite promising.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
