hi
tried everything when installing
the problem is with 4th gen processors (I think)
when installing the driver on to windows 10 insider build 14946 openGL dosnt get installed ????
is this ok ?
What's exposed by http://www.ozone3d.net/redirect.php?id=401 GPU Caps Viewer
OpenGL 1.1 and 2 extensions means Microsoft basic display adapter is active
OpenGL 4.x and 200+ extensions means hardware accelerated driver is correctly installed
DONT KNOW ABOUT THAT APP
I USE GPU-Z
BUT THE INFO ABOUT THIS PROBLEM I GOT FROM INTEL CONTROL PANEL - OPTION AND SUPPORT - INFORMATION CENTER
(BY THE WAY THE DRIVE 4530 WORK PERFECT)
Hello Genesys,
I am really sorry for any inconvenience that you may have due to this matter,
I will be more than glad to help you with your current concern. Due to this reason in order for me to be able to do more research and assist you, I would like to know the following:
Model of the equipment that you are using?
If it is not an Intel® device. I would like to know the model of your processor.
Hope I can hear from you soon.
Angie
Hello Genesys,
I would like to confirm if you will be able to provide me the following:
Angie
Hi the model is core I7 4790k
intel hd graphics 4600
on a gigabyte z97x gaming gt (bios f7)
32gb ram
anything else ?
also a problem with intel ark information about hd 4600 supported directx - in intel ark says 11.2 - in real life its 11.1
any idea's ?
Hello Genesys,
In order to help you, could you please install the following latest driver, in order to test if your issue can be solved:
https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496 Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
If this driver does not solve your issue, could you please reply to me with the model of the current equipment that you are using (laptop or any other device)?
Angie
Hello Genesys,
I would like to know if your concern was solved with the driver update?
If the issue continues, do not hesitate to reply back and let me know.
Also which will be the model of the current equipment that you are using (laptop or any other device)?
Or which will be the model of your processor?
Angie
Hey Angie
all work's fine with this build 20.19.15.4531 - this one 20.19.15.4539 is not good 4 me
running i7 4790k hd 4600 z97
Hello Genesys,
In regard to your concern, thanks for reporting this bug.
I would like to know if you could be able to install the latest driver for your current graphics:
https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496 Intel® HD Graphics 4600
And please let me know if you still have any issue.
Please let me know how it goes.
Angie
Hello Genesys,
I would like to know if the information that I have provided to you was able to help you with your issue?
In case if you need further assistance do not hesitate to reply back.
I am looking forward to heard from you.
Angie.
