Hello Shrouded5956,
Thank you for reaching out and sharing details about your setup.
To better assist you, kindly share the following information:
- What is the current driver version installed for your Intel Arc B580?
- Have you updated your monitor's firmware?
- Did you try different DisplayPort Cable?
- Have you tried contacting LG regarding this?
- Is HDR enabled in the Intel Graphics Software?
- Have you tried testing this issue with another Monitor?
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
I look forward to your response!
Robbie R.
Hello Shrouded5956,
Robbie R.
Hello Shrouded5956,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Robbie R.
