22933 Discussions
No Intel desktop board was detected in this system
NDAma
A few weeks ago I reinstalled Windows 7 Pro on my Dell Optiplex 9020.
I installed all the drivers from Dell, but I think something may be off with the display drivers. Sometimes scrolling feels sluggish and there is sometimes lag when typing. My main problem is when I run Adobe Flash CS5 (and even my older CS4) the textfields in the UI glitch. The cursor switches from the default pointer to the edit text pointer. Instead of the program checking if the cursor is in the text field once it seems to check every time the cursor is moved, resulting in an annoying flicker: https://www.youtube.com/watch?v=3384GUw0yec IMG 07921 - YouTube
Could this be related to graphics drivers?
I tried to update the Intel drivers with the update utility but it says "A customized computer manufacturer driver is installed on your computer." I tried to manually update, but I wasn't sure of my desktop board. I ran the desktop board utility and it said there was no Intel desktop board was detected in this system.
Anyway, could the weird cursor glitch be a result of the display drivers?
Thanks!
Silvia_L_Intel1
Hello Cminor, thanks for joining the Graphics Community.
We always recommend customers to download and install the drivers provided by the system manufacture, since our drivers are generic drivers and sometimes these cannot be installed on other systems or the installation of them could overwrite their customizations and possibly change the functionality of the graphics.
Would you please let me know which Intel driver version did you installed on your system?
Have you tried installing the previous version available?
Could you please attach the DX Diag report from your system?
(Start -> Run -> dxdiag -> Save All Information).
NDAma
I installed the drivers from http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-9020-desktop/drivers this page. Most of them were done automatically by Dell system analysis. However, this one keeps repeatedly showing up as an available update:
Intel(R) Management Engine 9.0 Components Installer Driver http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=6FDV2&fileId=3281284866&osCode=&productCode=optiplex-9020-desktop&languageCode=en&categoryId=CS View full driver details
Chipset_Driver_6FDV2_WN_9.0.13.1402_A02.EXE | Chipset (52MB) | Recommended No matter how many times I install it, automatically or manually, it doesn't seem to work. The Intel 8 Series Chipset Device Software Driver also shows up as an available update but I have another PC of the same model that does the same thing.
I appreciate the help. Here's the report:
System Information
Time of this report: 2/18/2015, 10:02:08
Machine name: NICK-PC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150113-1808)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: OptiPlex 9020
BIOS: BIOS Date: 11/20/14 20:15:14 Ver: A09.00
Processor: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz (8 CPUs), ~3.6GHz
Memory: 16384MB RAM
Available OS Memory: 16292MB RAM
Page File: 2484MB used, 30097MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_05A41028&REV_06
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: G247HL
Monitor Id: ACR03FA
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HD15
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3412 (English)
Driver Version: 10.18.10.3412
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 1/22/2014 12:51:34, 19380224 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-CC7E-AE25BBC2C735}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0x05A41028
Revision ID: 0x0006
Driver Strong Name: oem25.inf:IntelGfx.NTamd64.6.1:iHSWD_w7:10.18.10.3412:pci\ven_8086&dev_0412&subsys_05a41028
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVertical...
