23806 Discussions
No graphics card found?
MTild
Hello everyone,
I have a serious issue with my pc at the moment, no matter what I try she can't seem to recognize anything related to the graphics card, which makes it impossible for me to run anything Direct3D related. If you are willing to help please respond and I'll send my dxdiag, the problem might become clearer the moment you take a look in the display devices dept. please help. Thanks in forward
MTild
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Current Mode: 1280 x 1024 (32 bit) (1Hz)
Monitor:
Monitor Max Res:
Driver Name: vga.dll
Driver Version: 5.01.2600.0000 (Dutch)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 9/7/2001 11:00:00, 9344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n.v.t.
Mini VDD: vga.sys
Mini VDD Date: 4/13/2008 23:14:42, 20992 bytes
Device Identifier: {D7B70EE0-4340-11CF-B063-282AAEC2C835}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: All tests were successful.
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
**nvm, posted it seperatly**
Kevin_M_Intel
Hello MTI,
Can you please post the complete dxdiag report?
MTild
System Information
Time of this report: 9/3/2013, 19:06:42
Machine name: XP-62075CB514EC
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130704-0421)
Language: Dutch (Regional Setting: Dutch)
System Manufacturer: Dell Inc.
System Model: Inspiron 530
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Genuine Intel(R) CPU 2140 @ 1.60GHz (2 CPUs)
Memory: 1014MB RAM
Page File: 470MB used, 3445MB available
Windows Dir: C:\WINDOWS.0
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: None
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The system is using the generic video driver. Please install video driver provided by the hardware manufacturer. DirectDraw test results: All tests were successful. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Monitor:
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n.v.t.
Mini VDD: vga.sys
Vendor ID: 0x0000
Device ID: 0x0000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Registry: OK
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1028020D&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.6662 (English)
WHQL Logo'd: Yes
Date and Size: 6/19/2012 17:54:20, 6141584 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS.0\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI-mapper (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable-software (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Muis
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Toetsenbord
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC529
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-hoofdhub
| Vendor/Product ID: 0x8086, 0x2935
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 23:15:38, 59520 bytes
| Driver: usbd.sys, 9/7/2001 11:00:00, 4736 bytes
+-+ USB-HID
| | Vendor/Pro...
