22885 Discussions
"Display Power Saving Technology" setting not saved
GSlaz
I'm using Asus Zenbook Prime, with Intel HD 4000, driver version 9.17.10.2843, Windows 8
When unplugged from power, I've noticed that the screen can get really ugly (washed out colors), I've noticed that it's related to the option "Power\Power Conservation Features\Display Power Saving Technology" in the Intel Graphics and Media Control Panel.
After I've disabled this option, everything looks great again, but when I restart the computer, the colors get washed out again.
As I understand the setting is not saved, and everytime I restart the computer, it gets restarted to the default setting.
Please make it to be saved!
DArce
Valued Contributor III
Please post the dxdiag report from your system.
In addition, please confirm if your system uses more than one video controller in a switchable graphics configuration.
Was it working fine before? Was any change done to the system before this started to happen?
GSlaz
My laptop is brand new, it has Intel 4000 HD and GeForce 650m.
It's happening all the time, since I've bought it.
Here's the dxdiag:
[quote]
System Information
Time of this report: 8/30/2013, 16:48:18
Machine name: ZENBOOKPRIME
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130531-1504)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: UX51VZA
BIOS: UX51VZA.204
Processor: Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
Memory: 8192MB RAM
Available OS Memory: 8078MB RAM
Page File: 3418MB used, 9266MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 144 DPI (150 percent)
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_15A71043&REV_09
Display Memory: 4038 MB
Dedicated Memory: 1990 MB
Shared Memory: 2048 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD0323
Native Mode: 1920 x 1080(p) (59.975Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2843 (English)
Driver Version: 9.17.10.2843
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread group
Driver Attributes: Final Retail
Driver Date/Size: 8/31/2012 14:35:14, 12601856 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-4226-11CF-F27B-AA35B4C2C435}
Vendor ID: 0x10DE
Device ID: 0x0FD1
SubSys ID: 0x15A71043
Revision ID: 0x00A1
Driver Strong Name: oem4.inf:5f63e5341859ec8c:iIVBM0:9.17.10.2843:pci\ven_8086&dev_0166&subsys_15a71043
Rank Of Driver: 00E00001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_VLD DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
DArce
Have you tried to update the BIOS on this laptop?
In addition, please try using the latest nVidia* driver that is provided by your laptop manufacturer (9.18.13.1146) and check again.
Only after trying that, if the issue persists, then test using our generic driver posted here:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers
GSlaz
I've bought the laptop 2 weeks ago, and I'm not sure if it requires a BIOS update, besides I don't want to try that, as I don't want to risk something going wrong with it, as right now I can't afford having non-workable laptop, sorry.
The Nvidia driver from Asus website is actually older than what I currently have. On Asus website there's 311.46, and I have latest 320.49 WHQL from Nvidia website.
I've tried installing the Intel driver from your link, and upon starting the "Setup.exe" I get the message:
Error
The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer.
Setup will exit.
OK
DArce
You should also test with the latest nVidia* driver that was provided by your laptop manufacturer as this what was validated and tested by your computer manufacturer. Not to mention that this would be a good troubleshooting step to start with.
Concerning our driver, please be aware that we provide generic drivers that have not been developed or tested specially for your system, that is the reason you get that message saying that the driver has not been validated for your system
If you still need to use the generic drivers, you can try to force the generic driver by uninstalling the driver that was provided by your laptop manufacturer, this is done through the Control Panel, go to programs and features (in Microsoft* Windows* 7/Microsoft* Windows* 8 or Microsoft* Windows* Vista*). Then locate any entry similar to Intel® Graphics Media Accelerator or video driver and remove it. After that, restart your system and try to install the generic driver again.
You can also try to force the driver with the instructions on this site:
http://www.intel.com/support/graphics/sb/CS-033916.htm http://www.intel.com/support/graphics/sb/CS-033916.htm
If the issue persists you should check with your laptop manufacturer for assistance on updating the system BIOS and to check for further troubleshooting on this issue.
GSlaz
Turns out that Asus installs on brand new laptops Power4Gear Battery Saving plan, which activates when the power cable is unplugged, and in the advanced settings of the plan, there was an option "turn on the display power saving technology" which was set to true.
I've disabled that, and hope it will resolve the issue.
