22695 Discussions
No scaling option available
JavaGuy
I have a Celeron N5095 PC which connects the display to a Samsung TV.  I have updated the latest drivers.
The screen resolution is set to 1920×1080 as recommended.  However the display is a little bit over scaling on the TV.
On the latest Intel® Graphics Command Center (version 1.100.3408.0), there is ONLY "Maintain Aspect Ratio" option available in the Scale setting.  I can't adjust the scale.
If I change the screen resolution to a smaller size, then other options becomes available.
Can I keep the resolution to 1920×1080 and turn down  the scaling a little bit?
thx
Java Guy
AlHill
Look on the TV for video settings.  You should see something like native or natural.   Select one or the other.
JavaGuy
I didn't see the "Native" or "Natural" setting in the video section.  I clicked on the "Restore default profile setting" and it fixed the the issue.
thx
JavaGuy
