23525 Discussions
No way on my device
Johannes_S_1
Hey supporter,
I don't know if I'm right with that problem here but I don't know where to go.. Fact is that I can't get Vulkan to work on my device..
Am I just too silly and I'm annoying with that report... ?   I don't know but I give it a try 😉
First. System specifications:
System Used: Microsoft Surface 4
CPU: Intel Core i7 - 6650U 2.2 GHz
GPU: Intel Iris Graphics 540
DRIVER VERSION: 20.19.15.4409 (recent driver : updated)
OPERATING SYSTEM: Windows10 64 Bit
The problem:
As I like to compile code I get instantly following error:
Could not create Vulkan instance:
ERROR_OUT_OF_HOST_MEMORY
If I like to run a installed programm using Vulkan this shows up:
Could not find Vulkan components...
So, is the updated driver not the driver I was looking for?
Network didn't help me out so far.
Thanks for support in advance!
Michael_C_Intel2
Hi Johannes,
Vulkan support is only available in a beta driver:
https://software.intel.com/en-us/blogs/2016/06/29/new-intel-graphics-test-driverdriver-for-windows-10-and-windows-781-15404473
Support is not included in any certified driver yet. In order to get Vulkan support you need to use the beta driver. However using a non certified driver on your Surface Pro 4 may be problematic.
-Michael
