23829 Discussions
Not able to install graphic driver
liftinl
Hi
I am using desktop PC with following specifications:
OS - Windows 7 Ultimate (ServicePack -1),
Processor - Intel (R) Pentium(R) D CPU ; RAM - 2 GB
Here, i am not able to install any graphic driver for the above specified PC.
Even, i am not able install "Intel driver and support assistant".
Pls guide me to overcome this problem.
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
liftinl
Pls find attached file.
AlHill
Sorry, but your system is just too old.  The best thing for you to do is to backup your data, take your system to a recycle bin, and get a much newer system.  All of your hardware is long discontinued, as well as is Windows 7.
