22894 Discussions
OneApp.IGCC.WinService.exe is still occupying WCF TCP Port Sharing port 808
What
Our product uses WCF port sharing for all it's communications between windows services.  I seen in a previous forum saying this should be addressed in 27.20.100.8783 .
I've downloaded and installed driver 30.0.101.1660 and it issue continues to persist.   I've included Intel Graphics Command Center's report and a pic of netstat -ab showing the issue.
It seems like the actual driver is not being updated when installing igfx_win_101.1660.exe.
Any help for addressing this issue would greatly be apricated.
Alberto_R_Intel
What, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
Did the WCF application work fine before with a different graphics driver version on this same PC?
If so, by any chance, do you remember that driver version?
When did the issue start?
Did you make any recent hardware/software changes that might cause this problem besides updating the graphics driver?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
What
Hey Albert,
This is a newly setup system that I'm using for development of our product so no this has not worked before on this PC.  I've attached the SSU logs and the dx_info logs which looks like it has the all the other information you need.  The only way I can get our product to use WCF Port-S
haring (port 808) is to kill OneApp.IGCC.WinService.exe.
The motherboard info is a Dell 0HV8FN Ver A01.
What
Alberto_R_Intel
Hi What, Thank you very much for providing that information and the SSU report.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello What, I just received an update on this matter.
In this case, upon checking the SSU and what you mentioned, it seems the driver is not updated, can you please try a clean driver installation? considering that the machine has hybrid graphics he may need to update his dGPU drivers too in order to update the system.
Dell has a newer version than the one the currently installed, please try a clean installation of OEM version 27.20.100.9664, You are currently 3 versions below the latest OEM driver:
https://www.dell.com/support/home/en-us/product-support/product/optiplex-7080-desktop/drivers
If the issue remains, please install the latest driver 30.0.101.1660:
https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html
Another thing we noticed is that the operating system is not up to date, please update the OS build as well. You can always contact Microsoft support if you need assistance in installing the updates:
https://support.microsoft.com/
Albert R.
Alberto_R_Intel
Hello What, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
DeividA_Intel
Hello What,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
What
Yes, please close this case.  Manually removing all my video drivers and then reinstalling from scratch fixed the issue I was having.
Alberto_R_Intel
Hello What, Thank you very much for letting us know those results.
Perfect, excellent, it is great to know that "Manually removing all the video drivers and then reinstalling from scratch fixed the issue", with the OneApp.IGCC.WinService.exe.
Any other inquiries, do not hesitate to contact us again.
Albert R.
