23851 Discussions
OpenCL Graphics Driver 30.0.101.1069 Issue
Scott_S_2
Hi all,
I have just upgraded to the latest Intel Graphics Driver and I can no longer build opencl programs from spirv.  It seems image3d write is broken/missing as I get the following error for a simple opencl kernel:
failed to build opencl program:
error: undefined reference to `__builtin_spirv_OpImageWrite_img3d_wo_v3i32_v4f32'
in function: '__builtin_spirv_OpImageWrite_img3d_wo_v3i32_v4f32' called by kernel: 'driver_test2'
error: backend compiler failed build.
 here is a simple kernel that triggers this:
#include <opencl_memory>
#include <opencl_work_item>
#include <opencl_image>
#include <opencl_integer>
using namespace cl;
kernel void driver_test(
    image3d<float4, image_access::write> dst_vol
    const int3 dst_coords(get_global_id(0), get_global_id(1), get_global_id(2));
    float4 source_sample(0.0f,0.0f,0.0f,0.0f);
    dst_vol.write(dst_coords, source_sample);
and the cpp part:
#include "CL/cl.h"
#include <iostream>
#include <fstream>
#define MAX_PLATFORM_SIZE 256
#define MAX_DEVICE_SIZE 256
std::vector<unsigned char> load_file(const std::string& file)
    std::fstream input(file, std::ios::in | std::ios::binary | std::ios::ate);
    auto size = input.tellg();
    input.seekg(0, std::ios::beg);
    std::vector<unsigned char> binary(size);
    input.read((char*)binary.data(),size);
    input.close();
    return binary;
void driver_test()
    std::vector<unsigned char> data = load_file("driver_test.spir");
    cl_device_id device_id[256];
    cl_platform_id platform_id[256];
    cl_uint ret_num_devices;
    cl_uint ret_num_platforms;
    char buf[4096];
    cl_int ret = clGetPlatformIDs(0, 0, &ret_num_platforms);
    ret = clGetPlatformIDs(ret_num_platforms, platform_id, &ret_num_platforms);
    if (ret != CL_SUCCESS) {
        std::cout << "something went wrong in clGetPlatformIDs" << std::endl;
        return;
    for (unsigned int i=0; i<ret_num_platforms; i++)
        ret = clGetPlatformInfo(platform_id[i], CL_PLATFORM_NAME, sizeof(buf), buf, NULL);
            std::cout << "something went wrong in clGetPlatformInfo" << std::endl;
            return;
        std::cout << "Platform[" << i << "]: " << buf << std::endl;
        ret = clGetDeviceIDs(platform_id[i], CL_DEVICE_TYPE_ALL, MAX_DEVICE_SIZE, device_id, &ret_num_devices);
            std::cout << "something went wrong in clGetDeviceIDs" << std::endl;
            return;
        for (unsigned int j=0; j<ret_num_devices; j++) {
            ret = clGetDeviceInfo(device_id[j], CL_DEVICE_NAME, sizeof(buf), buf, NULL);
                std::cout << "something went wrong in clGetDeviceInfo" << std::endl;
                return;
            std::cout << "Device Name: " << buf << std::endl;
            ret = clGetDeviceInfo(device_id[j], CL_DEVICE_VENDOR, sizeof(buf), buf, NULL);
                return;
            std::cout << "Device Vendor: " << buf << std::endl;
        std::cout << std::endl;
    cl_context context = clCreateContext( NULL, 1, &device_id[0], NULL, NULL, &ret);
    cl_int err = 0;
    cl_program program = clCreateProgramWithIL((cl_context)context, data.data(), data.size(), &err);
    if(err != CL_SUCCESS){
        std::cout << "failed to create opencl program with IL " << std::endl;
        return;
    // sometimes crashes here
    err = clBuildProgram(program, 1, &device_id[0], NULL, NULL, NULL);
    cl_int build_status;
    err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_STATUS, sizeof(cl_build_status), &build_status, NULL);
    if(build_status != CL_SUCCESS){
        size_t ret_val_size;
        err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_LOG, 0, NULL, &ret_val_size);
        std::vector<char> build_log(ret_val_size+1,0);
        err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_LOG, ret_val_size, build_log.data(), NULL);
        build_log[ret_val_size] = '\0';
        std::cout << "failed to build opencl program: \n" << build_log.data() << std::endl;
I've been rolling back the driver versions and the earliest driver where this happens is: 30.0.101.1069
Earlier driver version work fine
Sometimes it crashes at clBuildProgram too.
I have attached the .cl, cpp and .spir files.  We use:
    SPIRV-LLVM, SPIR, libclcxx
to generate the spirv file.  I've attached the generated spirv for easier testing.
Any help would be appreciated.
Scott
System Setup Information:
System Used: Inspiron 3670
CPU SKU: Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz 3.60 GHz
GPU SKU: Intel(R) UHD Graphics 630
System BIOS Version: Dell Inc. 1.3.4, 24/05/2018
Graphics Driver Version: 30.0.101.1069
Operating System:  Windows 10 Pro
OS Version: 10.0.19042 Build 19042
API: OpenCL
Occurs on non-Intel GPUs?: no tested
