22655 Discussions
OpenGL 1.4 support on HD 3000 and 4000
MWigm
I have a legacy product for Windows I am trying to support that uses OpenGL 1.4. It works perfectly on NVIDIA-equipped computers, but on anything with Intel integrated graphics HD 3000 or 4000 it crashes on loading. I've tried running in debug mode with glGetError() calls at various points but it has proved impossible to track down the source of the error. All I get is error code 0x00000500 - INVALID_ENUM. Any ideas where I should look? I have already installed the latest drivers from the Intel website.
Kevin_M_Intel
Hello wiggers,
It is important to mention that the Intel® HD Graphics 3000 & 4000 Controller supports OpenGL 3.1 and 4.0 respectively.
You can this information at the following link:
http://www.intel.com/support/graphics/sb/CS-033757.htm http://www.intel.com/support/graphics/sb/CS-033757.htm
As part of the troubleshooting steps, I recommend you installing the latest graphics driver we have from our side.
Can you please post your dxdiag information here so I can provide more information?
MWigm
Why is it important to note that OpenGL 3.1 and 4 are supported? Are you saying you don't support older versions of OpenGL? NVIDIA do! Also I don't see any means of attaching the dxdiag output file. How do I do that please?
MWigm
Here is the information from this machine, but I've had the same problem on other machines with HD 3000 and 4000.
Kevin_M_Intel
Hello wiggers,
In this case, I recommend you downloading the latest graphics driver we have in our site for your controller. We currently have the version 3062 and you are using version 2867.
You can download the driver at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22628&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
MWigm
Thank you. That driver has fixed the issue on the HP laptop with Intel HD 3000 graphics. Do you have one for Dell laptops with HD 4000 please?
I note that the download page advises users to get the drivers from the OEM rather than using the one provided by Intel, but this version was not available from HP. "To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer."
MWigm
Here is the dxdiag screen for the Dell 4 series laptop with the same problem. The only relevant driver I can find from Intel is 2869.
Kevin_M_Intel
Hello wiggers,
The driver for any laptop unit with Intel® HD Graphics 4000 can be downloaded at the following link:
For Windows* 7 64 bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=Drivers
For Windows* 7 32 bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22840&lang=eng&OSVersion=Windows%207%20%2832-bit%29*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22840&lang=eng&OSVersion=Windows%207%20%2832-bit%29*&DownloadType=Drivers
If you would like to download the driver for a laptop with the Mobile Intel® 4 Series Express Chipset, it can be downloaded from the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22165&lang=eng&OSVersion=Windows%207%20%2832-bit%29*&DownloadType https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22165&lang=eng&OSVersion=Windows%207%20%2832-bit%29*&DownloadType=
Note that all these drivers are the latest versions we have available from our download page.
O3m-A
Hi Guys,
I can't play Medal of Honor: Allied Assault (MOHAA, a video game that needs OpenGL) on my Windows 8 64-bit Laptop which has integrated Intel 3000 video. I've downloaded the latest version of the drivers here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Laptop+graphics+drivers&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000&ProdId=3319&LineId=1101&FamilyId=39 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Laptop+graphics+drivers&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000&ProdId=3319&LineId=1101&FamilyId=39
Unfortunately, these do not work either. The game crashes to desktop when I try to load it. Works perfectly on computers with Nvidia or ATI graphics. My other laptop has an Nvidia video card in it, and it runs the game fine.
Will there be more updates to the drivers to get this game to work? It's really pretty bad that Intel can't support older applications...
Kevin_M_Intel
Hi own3mall,
I am sorry to hear you are having problems but let me help you.
From our side we can provide the generic drivers for your system. You can download the drivers at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23377&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
It is important to say that even though the game is an old game it does not necessarily means that the controller will be able to run it. Due to this reason, I suggest you contacting the game manufacture to confirm if there may be a firmware update.
