23807 Discussions
OpenGL Issue
NWash1
Need help with an old pc trying to play an old game on it called Wolfenstein Enemy Territory. Here’s the issue.
ET 2.60b win-x86 May 8 2006
----- FS_Startup -----
Current search path:
C:\Program Files (x86)\Wolfenstein - Enemy Territory\etmain\pak2.pk3 (22 files)
C:\Program Files (x86)\Wolfenstein - Enemy Territory\etmain\pak1.pk3 (10 files)
C:\Program Files (x86)\Wolfenstein - Enemy Territory\etmain\pak0.pk3 (3725 files)
C:\Program Files (x86)\Wolfenstein - Enemy Territory\etmain\mp_bin.pk3 (6 files)
C:\Program Files (x86)\Wolfenstein - Enemy Territory/etmain
3763 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' 😞 succeeded
...setting mode 4: 800 600 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
AlHill
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
NWash1
posted a file.
AlHill
You have an E6600 processor from 2010. It does not contain intel graphics. You also have a B43 chipset, which does supply your graphics.
You are running Windows 10 version 1909.
Your processor and graphics are not supported. Your graphics driver is the Microsoft Generic Graphics Driver, which lacks features and performance.
You apparently have an HP SFF pc. If there is a slot available, you may find a compatible half-height graphics card from nvidia or amd which is still supported.
However, your best solution would be to take your system to the nearest recycling facility, and then purchase a new or newer system that is supported by Windows 10.
Sorry, but this is the reality of the situation.
Doc
NWash1
Alright thanks for the help.
