23686 Discussions
OpenGL and 82865G
I was trying to install the lastest drivers (14.17) for the 82865G, but it failed with the message "Der Treiber kann auf diesem Computer nicht installiert werden". So I tried to install 14.16, and the setup told me that there is a newer version installed already.
I just don't know how to make OpenGL work now ...
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 08.10.11 19:49
Minecraft: Minecraft Beta 1.8.1
OS: Windows XP (x86) version 5.1
Java: 1.6.0_27, Sun Microsystems Inc.
VM: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
(and so on)
RAlva5
if you want to rollback your installed driver from 14.17 back to 14.16, for windows XP operating system try opening your control panel then open administrative tool, then click system or computer (if I'm correct), below that you must find the device manager yourself then open the graphics display adapter then open the driver section then click the rollback driver.For windows 7, the same steps, just skip the administrative tool, then go to system security, then click system and so on....
