22866 Discussions
OpenGL bug only on Intel Iris XE
kodo_simio
The following code causes flickering geometry for me under the following conditions:
  • If multisampling is enabled at any sample resolution
  • If the GL_TEXTURE_2D_ARRAY txtures are rendered last (it doesn't happen if the GL_TEXTURE_2D textures are rendered last)
  • It only appears to happen on my Intel Iris XE integrated card and not on the dedicated NVidea one
The code is a complete program that only uses GLFW and GLM as dependencies.
I've stripped out all error checking code for brevity but I'm certain there are no explicit errors in the code.
If the code looks a little strange that's because it is extracted from a MUCH larger rendering API in a way that repos the issue.
Any help or insight would be greatly appreciated.
const char* tvc = R"(
#version 330 core
layout(location = 0) in vec2 a_position;
layout(location = 1) in vec2 a_uv;
layout(location = 2) in vec4 a_color;
uniform mat4 u_projTrans;
out vec2 v_uv;
out vec4 v_color;
void main()
    gl_Position = u_projTrans * vec4(a_position, 0.0, 1.0);
    v_uv = a_uv;
    v_color = a_color;
const char* tfc = R"(
#version 330 core
uniform sampler2D u_texture;
in vec2 v_uv;
in vec4 v_color;
out vec4 fragColor;
void main()
    fragColor = v_color * texture(u_texture, v_uv);
const char* avc = R"(
#version 330 core
layout(location = 1) in vec3 a_uv;
layout(location = 2) in float a_layer;
layout(location = 3) in vec4 a_color;
out vec3 v_uv;
out vec4 v_color;
void main()
    v_uv = vec3(a_uv.xy, a_layer);
    v_color = a_color;
const char* afc = R"(
#version 330 core
uniform sampler2DArray u_texture;
in vec3 v_uv;
in vec4 v_color;
out vec4 fragColor;
void main()
inline unsigned int create_shader(const char* vertCode, const char* fragCode, unsigned int textureLocation){
    unsigned int vid = glCreateShader(GL_VERTEX_SHADER);
    glShaderSource(vid, 1, &vertCode, NULL);
    glCompileShader(vid);
    unsigned int fid = glCreateShader(GL_FRAGMENT_SHADER);
    glShaderSource(fid, 1, &fragCode, NULL);
    glCompileShader(fid);
    unsigned int shaderID = glCreateProgram();
    glAttachShader(shaderID, vid);
    glAttachShader(shaderID, fid);
    glLinkProgram(shaderID);
    glDeleteShader(vid);
    glDeleteShader(fid);
    glUseProgram(shaderID);
    glUniform1i(glGetUniformLocation(shaderID, "u_texture"), textureLocation);
    return shaderID;
inline unsigned int create_texture_2d(int w, int h, void* data){
    unsigned int textureID;
    glGenTextures(1, &textureID);
    glBindTexture(GL_TEXTURE_2D, textureID);
    glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA8, w, h, 0, GL_RGBA, GL_UNSIGNED_BYTE, data);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
    glBindTexture(GL_TEXTURE_2D, 0);
    return textureID;
inline unsigned int create_texture_2d_array(int w, int h, int layers, void* data){
    glBindTexture(GL_TEXTURE_2D_ARRAY, textureID);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_WRAP_S, GL_REPEAT);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_WRAP_T, GL_REPEAT);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
    glTexImage3D(GL_TEXTURE_2D_ARRAY, 0, GL_RGBA8, w, h, layers, 0, GL_RGBA, GL_UNSIGNED_BYTE, data);
    glBindTexture(GL_TEXTURE_2D_ARRAY, 0);
    return textureID;
struct TextureVertex
    glm::vec2   position;
    glm::vec2   uv;
    glm::u8vec4 color;
struct TextureArrayVertex
    glm::vec2   position;
    glm::vec2   uv;
    float       layer;
    glm::u8vec4 color;
inline void make_textured_quad(TextureVertex* vertices, float x, float y, float width, float height, glm::u8vec4 color){
    float r = x + width;
    float b = y + height;
    vertices[0] = { { x, y }, { 0.0f, 1.0f }, color };
    vertices[1] = { { x, b }, { 0.0f, 0.0f }, color };
    vertices[2] = { { r, b }, { 1.0f, 0.0f }, color };
    vertices[3] = { { r, b }, { 1.0f, 0.0f }, color };
    vertices[4] = { { r, y }, { 1.0f, 1.0f }, color };
    vertices[5] = { { x, y }, { 0.0f, 1.0f }, color };
inline void make_textured_array_quad(TextureArrayVertex* vertices, float x, float y, float width, float height, float layer, glm::u8vec4 color){
    vertices[0] = { { x, y }, { 0.0f, 1.0f }, layer, color };
    vertices[1] = { { x, b }, { 0.0f, 0.0f }, layer, color };
    vertices[2] = { { r, b }, { 1.0f, 0.0f }, layer, color };
    vertices[3] = { { r, b }, { 1.0f, 0.0f }, layer, color };
    vertices[4] = { { r, y }, { 1.0f, 1.0f }, layer, color };
    vertices[5] = { { x, y }, { 0.0f, 1.0f }, layer, color };
inline void use_shader(unsigned int shaderID, glm::mat4& matrix){
    glUniformMatrix4fv(glGetUniformLocation(shaderID, "u_projTrans"), 1, GL_FALSE, &matrix[0][0]);
inline void bind_texture(GLenum textureType, unsigned int unit, unsigned int textureID){
    glActiveTexture(GL_TEXTURE0 + unit);
    glBindTexture(textureType, textureID);
template<typename VertexType>
inline void upload_and_draw(unsigned int vaoid, unsigned int vboid, unsigned int vertexCount, VertexType* vertices){
    glBindVertexArray(vaoid);
    glBindBuffer(GL_ARRAY_BUFFER, vboid);
    glBufferSubData(GL_ARRAY_BUFFER, 0, vertexCount * sizeof(VertexType), vertices);
    glDrawArrays(GL_TRIANGLES, 0, vertexCount);
int main(){
    if (!glfwInit()) return EXIT_FAILURE;
    int w = 900;
    int h = 500;
    glfwWindowHint(GLFW_SAMPLES, 4);
    glfwWindowHint(GLFW_CLIENT_API, GLFW_OPENGL_API);
    glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 3);
    glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 3);
    glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
    glfwWindowHint(GLFW_OPENGL_FORWARD_COMPAT, GLFW_TRUE);
    glfwWindowHint(GLFW_DOUBLEBUFFER, GLFW_TRUE);
    glfwWindowHint(GLFW_STENCIL_BITS, 8);
    glfwWindowHint(GLFW_RESIZABLE, GLFW_TRUE);
    glfwWindowHint(GLFW_VISIBLE, GLFW_TRUE);
    glfwWindowHint(GLFW_DECORATED, GLFW_TRUE);
    glfwWindowHint(GLFW_FOCUSED, GLFW_TRUE);
    glfwWindowHint(GLFW_MAXIMIZED, GLFW_FALSE);
    GLFWwindow* glfwWindow = glfwCreateWindow(w, h, "Test", NULL, NULL);
    if (!glfwWindow)
        glfwTerminate();
    glfwMakeContextCurrent(glfwWindow);
    glewExperimental = GL_TRUE;
    if (glewInit() != GLEW_OK)
        glfwTerminate();
    glfwSwapInterval(1);
    unsigned char whiteData[]{ 255, 255, 255, 255 };
    unsigned char blueData[]{ 0, 0, 255, 255 };
    unsigned char arrayData[]{ 255, 0, 255, 255, 0, 255, 255, 255 };
    TextureVertex      tvs[12];
    TextureArrayVertex avs[12];
    make_textured_quad(tvs + 0, 10, 10, 100, 200, { 255,255,255,255 });
    make_textured_quad(tvs + 6, 120, 10, 100, 200, { 255,255,255,255 });
    make_textured_array_quad(avs + 0, 230, 10, 100, 200, 0, { 255,255,255,255 });
    make_textured_array_quad(avs + 6, 340, 10, 100, 200, 1, { 255,255,255,255 });
    unsigned int capacity = 1000;
    unsigned int texVAOID;
    unsigned int texVBOID;
    unsigned int arrVAOID;
    unsigned int arrVBOID;
    unsigned int textureShaderID;
    unsigned int arrayShaderID;
    unsigned int whiteTexID;
    unsigned int blueTexID;
    unsigned int arrayTexID;
    glGenVertexArrays(1, &texVAOID);
    glBindVertexArray(texVAOID);
    glGenBuffers(1, &texVBOID);
    glBindBuffer(GL_ARRAY_BUFFER, texVBOID);
    glBufferData(GL_ARRAY_BUFFER, capacity * sizeof(TextureVertex), nullptr, GL_DYNAMIC_DRAW);
    glEnableVertexAttribArray(0);
    glVertexAttribPointer(0, 2, GL_FLOAT, GL_FALSE, sizeof(TextureVertex), (const void*)offsetof(TextureVertex, position));
    glEnableVertexAttribArray(1);
    glVertexAttribPointer(1, 2, GL_FLOAT, GL_FALSE, sizeof(TextureVertex), (const void*)offsetof(TextureVertex, uv));
    glEnableVertexAttribArray(2);
    glVertexAttribPointer(2, 4, GL_UNSIGNED_BYTE, GL_TRUE, sizeof(TextureVertex), (const void*)offsetof(TextureVertex, color));
    glBindVertexArray(0);
    glGenVertexArrays(1, &arrVAOID);
    glBindVertexArray(arrVAOID);
    glGenBuffers(1, &arrVBOID);
    glBindBuffer(GL_ARRAY_BUFFER, arrVBOID);
    glBufferData(GL_ARRAY_BUFFER, capacity * sizeof(TextureArrayVertex), nullptr, GL_DYNAMIC_DRAW);
    glVertexAttribPointer(0, 2, GL_FLOAT, GL_FALSE, sizeof(TextureArrayVertex), (const void*)offsetof(TextureArrayVertex, position));
    glVertexAttribPointer(1, 2, GL_FLOAT, GL_FALSE, sizeof(TextureArrayVertex), (const void*)offsetof(TextureArrayVertex, uv));
    glVertexAttribPointer(2, 1, GL_FLOAT, GL_FALSE, sizeof(TextureArrayVertex), (const void*)offsetof(TextureArrayVertex, layer));
    glEnableVertexAttribArray(3);
    glVertexAttribPointer(3, 4, GL_UNSIGNED_BYTE, GL_TRUE, sizeof(TextureArrayVertex), (const void*)offsetof(TextureArrayVertex, color));
    textureShaderID = create_shader(tvc, tfc, 0);
    arrayShaderID   = create_shader(avc, afc, 1);
    whiteTexID = create_texture_2d(1, 1, whiteData);
    blueTexID  = create_texture_2d(1, 1, blueData);
    arrayTexID = create_texture_2d_array(1, 1, 2, arrayData);
    while (!glfwWindowShouldClose(glfwWindow))
        glfwPollEvents();
        glfwGetFramebufferSize(glfwWindow, &w, &h);
        glm::mat4 matrix = glm::ortho(0.0f, (float)w, (float)h, 0.0f, -1.0f, 1.0f);
        glEnable(GL_BLEND);
        glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
        glDisable(GL_DEPTH_TEST);
        glViewport(0, 0, w, h);
        glClearColor(0.6f, 0.2f, 0.6f, 1.0f);
        glClear(GL_COLOR_BUFFER_BIT);
        use_shader(textureShaderID, matrix);
        bind_texture(GL_TEXTURE_2D, 0, whiteTexID);
        upload_and_draw(texVAOID, texVBOID, 6, tvs);
        bind_texture(GL_TEXTURE_2D, 0, blueTexID);
        upload_and_draw(texVAOID, texVBOID, 6, tvs + 6);
        use_shader(arrayShaderID, matrix);
        bind_texture(GL_TEXTURE_2D_ARRAY, 1, arrayTexID);
        upload_and_draw(arrVAOID, arrVBOID, 12, avs);
        glfwSwapBuffers(glfwWindow);
    glfwTerminate();
    return EXIT_SUCCESS;
IsaacQ_Intel
Hello kodo_simio
Please, create an account to submit your inquiry in our Intel Developer Zone, as the document you refer to comes from this website. So, you receive further troubleshooting support and get access to documentation.
Intel Developer Zone - Contact Page
Since the thread is related to the Developer Zone, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Isaac Q.
kodo_simio
You already gave this exact reply on the other question I posted - that link you gave isn't a contact page but an overview page. I followed the link to "Product Support Forums" and then clicked "Graphics". So where exactly am I supposed to post a question/bug like this? Can you give me a direct link please?
generalsquirrel
i have done multiple attempts for making a bug report for this opengl bug but it was not taken serious. (via twitter  among others) and via here but was ignored
kodo_simio
The problem is actually an error in the OpenGL code, not a driver bug. There should be a call to glBufferData before the call to glBufferSubData to orphan the buffer. Without this any data in the buffer not yet drawn gets trampled which causes the flickering.
This is particularly noticeable when the driver is under increased stress, such as when multisampling.
I can't find a way of deleting questions so I guess it'll just have to stay up.
