23837 Discussions
Output to option gone
AAlex27
I have a problem when I try connecting my laptop through a HDMI cable to an external monitor or the TV.
Until 2 days ago it worked just fine, but one morning when I opened my laptop, the monitor would not connect and the Output to option in Graphic Options is missing. I changed the cable as I thought this would be the problem, but unfortunately it is not working.
I must mention that when I opened my laptop that morning, it took a long while to open as it was making some updates. After these updates, the option dissapeared.
Also, the monitor is brand new and it worked perfectly and now suddenly the laptop does not see it.
Please help.
Thank you
Stefan3D
You provided no system infos.
Upload a report from https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility for Windows*
AAlex27
I uploaded the info. Any help would be appreciated.
Stefan3D
There is a brand new driver that supports your Valleyview processor under Windows fall creators update
https://downloadcenter.intel.com/download/27417/Intel-Graphics-Driver-for-Windows-15-33- Download Intel® Graphics Driver for Windows* [15.33]
Ignore the yellow bar that actually links to an older driver
To bypass message "best driver is already installed" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
AAlex27
I tried, unfortunately it is not working
