22655 Discussions
PC keeps freezing - new Asrock Arc 770
WhiteAfrican
Hi Intel team
Please help me with this frustrating issue:
I recently upgraded my gpu to the Arc 770 16GB OC edition.
I have had this weird issue where my pc screen freezes whenever I do a gpu intensive task like opening a game or opening premiere pro, or even running a bechmark.
When it happens i have to manually press, turn off my pc and restart when I want to use it again.
It doesn't happen every time, I have had session where I would play games and video edit for hours without it freezing but eventually is always does.
My specs:
Intel® Core™ i7-7820X CPU @ 3.60GHz
AUSUS PRIME X299-A Motherboard
64 GB Ram, running windows 11
1TB Samsung ssd
Intel driver:  31.0.101.5534
RamyerM_Intel
Hello WhiteAfrican,
Thank you for posting in the communities. As the Intel Arc A770 is the only recent change in your setup, I do want to ask, is your ReBar enabled in the BIOS? Please also list out the games/software that experiences the freezes so we can also check for common issues. Additionally, sharing your SSU logs will allow us to be more familiar with your configuration and check for possible errors.
Ramyer M.
WhiteAfrican
Hi RamyerM
Thanks for coming back to me. ReBar is enabled on the BIOS. I tested and experienced the freeze on Call of duty - warzone, overwatch 2, warcraft 3, premiere pro and the bechmark test app called furmark.
I have gotten some comments and messages suggesting that it might be that my PSU is connected to my GPU with one 8pin that splits to 2 for the gpu.
I will be testing that next, just waiting for a psu cable then I will be running my gpu from 2 separate pci-e cables to see if that solves my problem.
I will report back to you here when I have done that to update.
Juri
RamyerM_Intel
Hello WhiteAfrican,
Thank you for letting us know about the step that you want to take. We will be patiently waiting for the result. By the way may I please know where you saw this thread?
Ramyer M.
WhiteAfrican
Some people suggested this solution on the intel discord where i also posted. Also users on reddit did suggest this as well.
RamyerM_Intel
Hello WhiteAfrican,
I am just checking in on your system if everything is alright. Feel free to let us know if you need further assistance.
Ramyer M.
WhiteAfrican
Hi Raymer
I tried connecting my GPU with a extra pci-e cable but it ended up not working. Pc wont start. Not sure if its a faulty cable or what, i did order another cable so will test that soon.
For now i am still empiercing the freez but its weird today and yesterday I had no freezes or problems so I am not sure what is the trigger.
I  uploaded my system specs  for you to check out.
hope to hear from you soon
Juri
RamyerM_Intel
Hello WhiteAfrican,
Thank you for responding back. For now I can confirm that you are using the latest driver 31.0.101.5590 which is good practice for the Intel Arc A770 that you have. As that is the case, it would be best to proceed with the troubleshooting steps.
Kindly please follow this article: Random Freezes and Crashes When Using the Intel® Arc™ A770 Graphics Card
Let us know if the issue still persists after doing so.
I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello WhiteAfrican,
I am just checking on your system. Were you able to follow our previous recommendation? Should you have additional questions feel free to let us know. I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello WhiteAfrican,
We've noticed that there hasn't been a response for a few days, so we will be closing this thread. If you require assistance in the future, please feel free to submit a new question, as we will no longer be monitoring this one. Thank you for your understanding.
We wholeheartedly wish you every success in all your future ventures and may your path be lined with triumphs and fulfillment.
Ramyer M.
